debarker
Started by 69bsa650, April 17, 2024, 04:46:57 PM
69bsa650
I have an older LT 40 With the debarker only moves in one direction. The motor does not function in both directions. Thanks for taking time to answer this
WV Sawmiller
   I may be mis-reading this but as I remember the blade only spins when you are going forward. There would be no reason for it to turn on the return trip. At least that is how it my LT35 works IIRC.
I suspect that he is referring to the motor that moves the debarker in and out but he must return to clarify.
