Questions from a Prospective Sawyer
Started by jeepcj779, July 30, 2019, 06:42:11 PM
Walnut Beast
Just get a new decked out 75k dually. Then you won't have any issues pulling 😂😂
terrifictimbersllc
I was referring to thinking I've seen (I am not sure) that the need to display USDOTNC (intrastate NC) kicked in at 26001# combined GVWRs, like a few other states have it. Yes I realize that This is also a threshold for CDL but not confusing the two.
I once had a list of all 50 states weight requirements for having USDOTXY #. (XY is the abbreviation of the state and is displayed for intrastate carriers in commerce).  I'll try to find it.
In the meantime, here is an article from a compliance outfit, that succinctly describes how I understand the situation. It just doesnt have a list of the states.
https://woodruffsawyer.com/property-casualty/fleet-weight-regulations-dot/
And here is a 2012 NC link that says that 26001 pounds or more, in business,  needs a USDOTNC number. https://www.ncdps.gov/press-release/new-program-requires-intrastate-usdot-numbers
A company would be required to obtain a USDOT number if it operates a commercial motor vehicle in intrastate commerce that:
Has a gross vehicle weight rating (GVWR), a gross combination weight rating (GCWR), a gross vehicle weight (GVW) or gross combination weight (GCW) of 26,001 pounds or more: or Is designed or used to transport more than 16 passengers, including the driver, or Is used in transporting hazardous materials in a quantity requiring placarding pursuant to 49 C.F.R. Parts 170 through 185.
This requirement is not limited to "trucking companies." As defined by law, a "motor carrier" is any commercial enterprise that uses such vehicles in its business operation and as a result it is subject to Federal Motor Carrier Safety regulations.
trimguy
I have a 14' box truck for my day job. Gross weight 12,100 lbs.  The DOT pulled me over a couple of years ago and explained it to me. Over 10,000 lbs. You have to have a number , over 26,000lbs you have to have a CDL. My truck is a 3500      ( 1 ton ) . With DOT numbers you have to have everything a " big " truck has ( fire extinguishers, triangles, health card , etc. ) except the CDL. My argument was all the 1 ton pickups on the road and the officer said " probably , but I have you pulled over right now. ". This is in Georgia.
jeepcj779
@Crusarius, I am confident the Tacoma with the tow package can handle 4300 lbs just fine. Towing a heavy load is not usually the issue, stopping is, so in addition to the tow package, I will also have a properly calibrated brake controller, so I don't think there will be an issue towing just over 2/3 of the factory rated capacity.
@Walnut Beast, I already have the dually. Just don't want to use it for "business" purposes.
Walnut Beast
I think you will be fine towing that weight
jeepcj779
  We'll, if anyone was wondering, I decided to stick with the LT-50. It is already waiting on me at Woodmizer NC, so I didn't want to cancel on them. On top of that, my wife said I should go ahead and get the 50 because "you'll end up buying it next year anyway". I'll take the advice of some FF members and skip the sharpener/setter for now. That will offset the cost a bit. I'll reconsider getting my own sharpening stuff next time they go on sale.
  Thanks to everyone for all the advice.
Southside
That is a very reasonable way to go, you end up with mill to grow into and honestly, you will have enough to wrap your head around without worrying about sharpening your own bands.
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Bandmill Bandit
Quote from: jeepcj779 on July 31, 2020, 08:06:31 PM
Get a box of 7° trubo carbides when you pick up your mill. The value of the sharpening equipment is diminished quite bit with using the carbides. Resharp is a good option when you get 10MBF + per sharp cycle.
Walnut Beast
terrifictimbersllc
Congratulations, wishing you the best.  I doubt you'll think much about whether you made a good decision.
great decision.  I do not remember when your stint is over, but let me be one of the first to welcome you home to civilian life.  Thank you for your service.
jeepcj779
Thanks Doc. My "final out" was on the 29th. My terminal leave starts today and we leave Hawaii tonight. We'll be eating Smithfield's BBQ for dinner by tomorrow evening! Then I guess I'll start preping for the hurricane...
btulloh
Good luck on the new direction. It sure sounds like you've got a plan worked out, and a good one.
The best part is that you'll be able to get real barbecue. That alone will give you a good foundation for dealing with this hurricane we're expecting. Like all weather, we won't know what it'll be til it gets here.
Travel safely and good luck with everything. Be sure to let us know how that first barbecue works out.
HM126
Southside
Did you double check to make sure you didn't accidentally pack any souvenir lava?  ;D
jeepcj779
Don't worry @Southside. I didn't accidentally pack any lava belonging to the People's Republic of Hawaii.
   Reminds me one time when I heard a young Marine complaining about being stationed on Okinawa. A wizened old senior NCO said "Its our own d__n fault. As many Marines as have passed through this island, if each of us had just taken a half a seabag full of sand and coral home with us each time this place would be gone by now and we would not have to keep coming back."
   Welcome home. Enjoy the BBQ. Not sure if I'd want the Smithfields or Sonny's but either way I am sure you will do well. To be fair try them both. Which part of NC are you returning to?
   I know I am going into withdrawal not being able to see my grandson and granddaughter in Charlotte. Stay safe.
jeepcj779
  Hawaii has a rule about talking sand, rocks, lava, or pretty much anything else from the island (unless you are a resident selling it to the tourists - then its OK). The state is most protective of the black sand, green sand, and lava rock. I think the last one is kind of funny because the 2018 eruption created 875 acres of new land on the big island. All lava rock now. Anyway, I don't like the traffic and crowds much, but Hawaii is good for the most part. Good weather, lots to do (if you like hiking and beach related activities), you just have to know where not to go to stay out of trouble.
  We are heading back to Dunn, NC. I've never heard of Sonny's, so Smithfield's is definitely better! There is one about 10 min from the house.
Cjross73
Welcome back and congrats on retirement.  I'm in grantham so not far from you.
LT40, Stihl saw, Old green tractor
jeepcj779
It has been a long wait, but I am finally going to pick my mill up next Friday at Wood-Mizer Carolina. If anyone has input on what I should pay the most attention to, or what you wish you would have spent more time going over when you picked up a mill in the past, I would love to hear it. Also, thanks to Tammy at LogRite for helping me out with selecting the right cant hooks and a fetching arch.
Southside
I would say make sure you really understand how to set up and pack up the sawmill.  When setting it into the travel position there are a number of steps you have to take, in the right order, or things won't fit, could get bent, etc.  Likewise when setting the mill up to saw, knowing how to properly set the legs up will save you a lot of frustration down the road.
If possible I would record the training session so you have it for reference later on.
YellowHammer
Don't just assume that the mill is adjusted correctly, go over the basic procedure real time.  It should be dialed in, but even if it is, you will have a baseline in case something changes later on.
YellowHammerisms:
ladylake
Quote from: Bandmill Bandit on July 31, 2020, 10:49:57 PM
 Carbide would be  fine until you hit a pole barn nail , drywall screw, or lag screw.  Steve
terrifictimbersllc
Quote from: Southside on September 24, 2020, 10:46:05 PM
Cant improve on this advice.  Failure to comply can lead to:
sawmill pointing to the sky
sawmill rolling down a hill
sawmill tipping over
sawmill getting bent or broken
somebody getting hurt or worse
You may have to ask them to pack up and set up again if you want to see it, if they are demoing your mill, as you'll be engrossed in the operation and may run out of time to ask them to set it up again.   Packing up is the exact reverse of setting up except when setting up you are making judgments about how high to have the front 3 jacks before bringing the head forward.
Hopefully you're already familiar with towing.
Ask whatever comes to mind.   Enjoy the experience it only happens once.  Well, once per new sawmill.  :D
Quote from: ladylake on September 25, 2020, 04:30:14 AMCarbide would be fine until you hit a pole barn nail , drywall screw, or lag screw. Steve
I completely agree with Steve.  When sawing logs you are virtually guaranteed to occasionally hit metal, rocks, etc.  I trashed two "new out of the box" blades while sawing my last job which cost the customer $60, whereas the cost of carbide blades would have been $180.
There is no way to justify this to the customer.  Normal blade wear is my cost and the customer is not concerned whether I can saw 500 or 5,000 bf with a blade.  He certainly would care if the damaged blade cost was $90 vs $30.
