Jonsered 510 SP Gas/oil mixture
Started by bphelps38, May 02, 2007, 06:03:07 PM
bphelps38
Can someone tell me what gas/oil ratio to use for the Jonsered 510 SP.  Got the saw from an in-law but no manual.
Got a Stihl MS 270 and love it but the 510 is lighter and want to try for brushing.
Bob
sawguy21
I might catch some flak but I would suggest 50:1, same as your Stihl.
bphelps38
Thanks for the advice. It's much easier to have only one gas mixture around. I use Stihl oil so it should be good stuff.
Kevin
QuoteCan someone tell me what gas/oil ratio to use for the Jonsered 510 SP.
Manufacturer recommends 40:1.
sawguy21
Oil has improved since that saw was built. They did recommend 40:1 for the oil available at that time. I am running 50:1 in my Husky 35 and other than the noise, no problems at all.
SawTroll
Quote from: sawguy21 on May 03, 2007, 10:17:39 PM
I believe you are right.
My Jreds 621 from 1970 has been run on 50:1 Alky fuel with synth oil for years, with no apparent ill effect - it "calls for" 25:1...... :)
Information collector.
Trax
Here's a link to info on that saw
510 SP
I had a 520 SP for 23 years (all most the same saw) just sold it on ebay last fall it would run circles around a MS 270
Corley5
