Dovetail log Dog house
Started by sum1, March 03, 2024, 08:12:38 PM
sum1
Figured I would try my hand at a dovetail project. Logs are 2.25"x3". Hardwood flooring because the dog is spoiled. Thinking I will use some cedar shingles.
What should I chink with?
Southside
Make sure your chinking will be able to stand up to the air pressure from the central heat and A/C system, or are you going with mini splits?  ffcheesy
White Oak Meadows
sum1
Quote from: Southside on March 03, 2024, 08:34:27 PMMake sure your chinking will be able to stand up to the air pressure from the central heat and A/C system, or are you going with mini splits?  ffcheesy
I was thinking wood stove. Training may be required.
Nice work on the dog house. If for the dog, no chinking. Am sure would enjoy the fresh air.  ffcheesy
If for you, then yes, and lights, AC and the heat system.  ffwave
scsmith42
Quote from: sum1 on March 03, 2024, 08:37:11 PM
What?? No radiant floor heating??  Man... poor pooch!
Tom's 3638D Baker band mill
rusticretreater
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
mike dee
https://www.permachink.com
Fill the gaps with spray foam, trim smooth, cover with permachink.
Bozeman Saw 26"x124"
doc henderson
sum any pics of the jig or how you cut these?  looks a little "ruff" to build.  glad you got all the "bark" off the logs.  looks like you left a "tail wagging" on the ridge beam. ffsmiley
Stephen1
Quote from: mike dee on March 04, 2024, 07:19:05 AMhttps://www.permachink.com
I would definitely use the permachink. Use  foam backer rod instead of the foam.
sum1
Quote from: doc henderson on March 04, 2024, 08:03:16 AMsum any pics of the jig or how you cut these?  looks a little "ruff" to build.  glad you got all the "bark" off the logs.  looks like you left a "tail wagging" on the ridge beam. ffsmiley
I cut at the joints on the bandsaw. I did make a jig at first for one end but I found it was too easy to cut into it with the bandsaw. I ended up marking all the pieces with a template and free hand cut them all. I used 15 degrees and went for 3/16" gap on the logs.
I also trimmed the ridge beam today and added cedar shingles.
doc henderson
