Your well pump will run a lot less with a bigger tank. Your 2.5 gallon tank probably only fills up to under a gallon of water, so every time you use that amount your pump is cycling on and off. I have a 120 gallon tank in our house FWIW. I think the draw down is 40 something gallons, so my pump would cycle 1/40th of yours under the same use.
Started by mrbullzi on Firewood and Wood Heating
Started by Paschale on General Board
Started by woodmills1 on General Board
Started by ecrane99 on Firewood and Wood Heating
