Dust collection
Started by KWood255, February 16, 2024, 10:23:59 AM
moodnacreek
A drag chain set up can be almost silent and not leek fine dust in the air. A problem with a trough or conveyer along side the mill is that that space, in my mind, should convey lumber or slabs. I use blowers because a drag would block access to the slabwood saw. With a circle or wide band the saw does not move so that helps.  Those going down this road should visit as many other mills as possible.
barbender
 The main reason my mill still has the axle and wheels under it is so I can move it out of the way and push the mess of sawdust and bark off to the side into the big, huge pile I don't know what to do with😁
 The only band mills with blower set ups I've got to see are on the Forum.
oldgraysawyer
I went to look at a band mill a few years before I actually got the one I currently have and he had put down a large tarp in the guys yard for clean up. I thought it was a fairly low budget solution for mobile sawing.
DB in WV
I occasionally have customers lay a tarp down to collect sawdust and afterwards use a leaf blower to disperse any remaining debris, etc.
61 is coming.
