Author Topic: Options utilize big trunk  (Read 800 times)
Offline esarratt
« on: April 16, 2020, 12:26:00 PM »
I am building an 8x10 timber frame shed.  This is my first little project before I start building my house.
The trunk of the oak tree I plan cut is about 3' diameter at the base (see pics).
I can easily imagine how to use wood which is 14" or smaller in diameter, but I am lost as to how to COMPLETELY use such a large trunk.
My thinking is to box heart the center and cut posts/beams out of the rest.
OR
Is a trunk this nice--it is quite straight, best for shingles?
OR
I am just looking for ideas.
Thanks!
Offline RPF2509
Re: Options utilize big trunk
« Reply #1 on: June 30, 2020, 01:41:27 PM »
Good thing it didn't fall the other way
Offline Tamarack
« Reply #2 on: June 30, 2020, 06:49:57 PM »
Wow be careful lots of tension there.
Offline GullyBog
  • It's not business, It's personal
« Reply #3 on: July 03, 2020, 06:45:47 AM »
I don't know anything about shingles.  That looks like a red oak.  I'm imagining a shed built out of just one tree.  A wiser man would design a shed and mill the tree to meet parts of the cut list.  I would mill the tree and then figure out how much shed I could build with the results.  A lot of the sheds and barns around here are "balloon frame" where the studs are 4 feet apart and the oak siding is structural.  That cut list would be 2x4's for the walls and rafters, 1" boards for the siding, flooring, and perlins.  Estimating the board feet in the tree is pretty easy, I have no idea about how to estimate shingles.
There might be a little dust on the butt log, but don't let if fool ya bout what's inside
Offline luap
  • Not as good as I once was
« Reply #4 on: July 03, 2020, 08:01:01 PM »
I would be planning how to move it before what I would cut it into. Putting 30 inches for mid point diameter of 8 foot log in the weight calculator it shows 2500 # and on a sidehill besides. And that's just the first log. At least it is accessible by road and you could get some kind of machinery to it. You tuber lets dig 18 just weighed a similar log and it was 4300# and he had an excavator and a front end loader to move the logs and control the stump when cut off.
Offline Southside
    • White Oak Meadows
« Reply #5 on: July 03, 2020, 08:24:24 PM »
Personally I would look to get my siding out of the jacket boards and as grade dropped get my timbers from the lower grade, interior wood, until such time they became compromised.  Of course the log will let you know what options you have as you begin to open it up.
White Oak Meadows
Designs/ plans that utilize short timbers
Started by Todd on Timber Framing/Log construction
Last post January 01, 2008, 06:27:29 PM
by Thehardway
Options, Options, OptionsMoney
Started by Doesmarlowknow on Chainsaws
Last post February 05, 2019, 07:19:49 PM
by Al_Smith
Grand-pa's old trunk
Started by Riggs on General Board
Last post September 28, 2014, 05:58:38 AM
by timberlinetree
B-20 trunk (for junk)
Started by Tom the Sawyer on Sawmills and Milling
Last post May 21, 2012, 08:42:52 PM
by WDH
