Pre-Surveying Sawjobs
Started by Magicman, July 14, 2013, 05:06:34 PM
I normally do not make an extra trip to look at an upcoming saw job, but I was in the neighborhood so I did look at one today.  It is 127 miles away and I plan to start sawing on the 22nd.
60 SYP logs to be sawn into framing lumber for the customer's new home.  He is providing meals and lodging and we should be able to easily lay that job by in 3 days.
I do always talk on the phone at length with new customers detailing the needed setup, and sometimes they will email me pictures.  So far I have a good track record and I have never been "bitten" by not looking at saw jobs.  Yes, I have lost an hour or so a couple of times getting things re-arranged, but fuel and time wise, I am still ahead.
drobertson
Looks like a nice place to work, much shade! nice looking logs as well,  david
What you can not see is the water after a week's rain.  I will set up on higher ground and the logs will be skidded to the sawmill.
POSTON WIDEHEAD
Quote from: Magicman on July 14, 2013, 06:27:31 PM
You do have a De-Barker?
Oh yes, and by next week it will have a new blade.   ;D
Somebody failed to retract the log turner and shelled the teeth off of his Debarker blade.   :-\
JustinW_NZ
Quote from: Magicman on July 14, 2013, 08:35:01 PM
sounds like a story  :D
Cheers
Justin
Gear I run;
drobertson
Done that, but with the blade, cotton pick'n turner was hiding behind a large nub,
Red Clay Hound
Is that sunshine I see in that photo? ???  I haven't seen the sun since I got home from Wyoming last week!  At least I didn't need my umbrella for shade while I was sawing on Saturday.  :D
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
Nomad
     I Hate it when that happens.  Are you gonna get one of the new wider tooth blades?  I'd  like to hear what you think of that type of blade if you do.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Yes, sunshine then, but it was not long before it was raining again.   :-\
Nomad, it seems to me that with some size logs, only the bottom corner would be contacting the log, and surely it would be more of a strain on the motor/breaker to have to plow through another ¼ of bark.  Since mine is running true with the blade, my thoughts were to go back with the ¼" blade.
LeeB
They're not hard to adjust to keep the thinner ones tracking with the blade.
Nomad
Quote from: Magicman on July 14, 2013, 09:56:58 PM
Quote from: LeeB on July 14, 2013, 10:36:35 PM
     My thoughts exactly.
Lucas DSM23-19
Today's saw job was very typical.  Mostly 8' logs, a level shady spot for the sawmill and the customer has a boom pole on the tractor.  No pre-survey necessary.   :)
