DIY Charcoal
Started by metalspinner, February 15, 2012, 06:54:08 PM
metalspinner
I'm not sure the best place for this discussion...
Charcoal is getting expensive.  We usually buy Kingsford briquettes because they reliably start and burn.  But the "big" bag is pushing $10 now.  Sometimes Lowes might have a buy one get one free, but that is rare.
The last bag I picked up was Royal Oak Natural Charcoal.  This appears to simply be fired wood that's been snuffed out, filtered and bagged.  My burgers are grilling over the coals as I type this. ;D  So it got me to thinking...
I have plenty of hardwood -  just about any Appalachian hardwood, an outdoor firepit, a match, a bucket of water, and a solar kiln.
Is it more complicated than this?  This sounds like an interesting Saturday morning project.  What do you guys think?
Mooseherder
I have been buying the bags of oak and hickory firewood at the store to use on the grill.
A five dollar bag lasts twice as long as a ten dollar bag of charcoal.
I split them into 2 inch slices and use my radial arm saw to cut them into chunks.
Use a little charcoal to start and when the coals are ready put the wood on top.
Cooks great! :)
metalspinner
Mooseherder,
I've got so much scrap around, your plan has crossed my mind, too.
Using a charcoal chimney got these bagged natural coals fired up really fast - under 10 minutes. My usual process is to light briquettes then make my patties in the 20 minutes it takes them to get briquettes going. But tonight, I almost got in trouble because the natural coals were ready to go in under 10 minutes.
The burgers were pretty tasty cooked over the natural coals, BTW. food6  I did notice the fire was not as hot as usual.
zopi
making charcoal is stupid easy...getcha a fifty five gallon drum...cut both ends out and set it up on blocks where a fire can be built under it..think of the barrel as a chimney..poke four holes in the lower third of the barrel...run two pieces of heavy rebar through..this is to the 20 or 25 gallon grease drum on...you need one with a close fitting top. poke about a dozen sixteen penny nail holes in the lid of the little barrel..pack the little barrel about half full of hardwood chunks..no bigger than two by two or so..little chunks convert easier...flip this mess upside down, and lower it onto the rebar in the big barrel...now build a nice hot fire under the big barrel and let her sit...pretty soon you will see jets of steam out of the nail holes which will soon catch fire as the woodgas comes out of the wood..if all works well, these jets will self sustain and burn until the wood is charcoal.  let it burn out and cool to ambient without disturbing the retort..if you have a coal in the retort and oxygen hits it your whole batch will go up quick...once it has cooled, flip the little barrel over and sort your charcoal..any still woody chunks need to go back through, although I am not too picky about it. I made about thirty gallons of softwood charcoal last week for the foundry...need to make a batch of white oak charcoal..am feeling bbqish..
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
metalspinner
Thanks, Zopi.  I just noticed your mention of making charcoal in your "foundry" post.
As with most of my wonderings, though, things are a bit more complicated than I originally thought. :D
Check this guy out...
http://www.youtube.com/watch?v=fHiyOP0PqMY&feature=related
At some point in the video, he's smoking a cigarette.  Seems kinda strange - like giving a drowning man a glass of water. ::)
Norm
Well I'm the lazy kind and buy lump by the pallet.  :D
Looking forward to what you come up with Chis.
gspren
Quote from: zopi on February 15, 2012, 08:12:30 PM
  I am trying to picture exactly how you do this and it sounds like the nail holes will be on the bottom of the small barrel while burning so how can you see it? Maybe I am missing something.
paul case
Here is an old thread about making charcoal that is well worth the read, it even has a video and some detailed instructions. PC https://forestryforum.com/board/index.php/topic,17666.0.html
pc
Al_Smith
If you have a slash/burn pile after you've burned a bunch of brush just dig through the ashes .You'll find enough charcoal to last you for a while . Pile the big pieces of whatever you want to coal up on the bottom of the pile and light off the brush .If it gets enough ash coverage you'll get plenty of coal .If not a majority of it will burn up .Lazy mans method .
Burlkraft
I just burned a 3 year accumliation of tops, some slabs and a bunch of stumps. We had have Oak Wilt pretty bad and I've had a few die.
Some of them stumps have been burned 3 or 4 times now. They are all oak so I have been makin' a harvest after each burn.
There's a lot a charcoal in them stumps yet.
Why not just 1 pain free day?
SPIKER
I saved a lot when I make syrup as I get 25 or 30 gallons a day and make a fire to give the NEW collected sap once prior to storing it for a day or two.   I burn good wood on somewhat closed up fire pit with the pan on top.   I get the batch going a real good boil after work I usually run out of time/daylight.   so often put out the fire with a bucket of water leaving 2/3 full fire pit of chard wood & charcoal.   close up the sap, and cover over the pit (sometimes it re-ignites even covered over & burns back to all charcoal or ash... :( )
I keep out a lot of the big natural charcoal hunks for summer BBQ.   I like to BBQ on wood fire as much if not more than charcoal anyway but still have about 3 5 gallon buckets left from last year...
mark
Mooseherder
I'm thinking kiln dried wood chunks for cooking may be less work and actually better than charcoal.  Just a theory I'm leaning towards. :D
That is what Tom would do.
Mooseherder
He sure knew what was good.  The flavor of a good steak on a hot oak wood fire is something worth raving about. :)
He sure did.  I miss him.
Dodgy Loner
I had a dream about Tom last night. I only met him in person once, bet he certainly made a lasting impression on me. I miss him too :'(
Dodgy Loner
Quote from: Mooseherder on February 15, 2012, 07:04:45 PM
I have been buying the bags of oak and hickory firewood at the store to use on the grill. A five dollar bag lasts twice as long as a ten dollar bag of charcoal.
Mooseherder, I just wanted to let you know that I tried your idea tonight, and it worked great! I'm in the middle of building a bed out of QSWO for my wife, so I just grabbed some appropriately-sized chucks from the scrap barrel and grilled a meal of chicken breast, steamed veggies, and garlic toast. It was a little different than cooking on charcoal, but I'm sure with a little practice I'll get good at it. Sure beats just burning all my white oak scraps on the campfire!
If I burned scraps from my workshop, I could save a fortune  :).
Mooseherder
I wish we lived closer to you guys.  I'd buy your scraps. :D
We cooked some smoked sausage and burgers tonight over wood chunks I had cut.  They were good. :)
Stop by on your next road trip and I will fix you up.
Mooseherder
Sounds like a great plan.  :)
LeeB
I prefer wood over charcoal myself.If I don't have enough scraps from the shop, I just split down a couple of sticks of firewood. When I do use charcoal, it's a local made lump charcoal made just up the road a couple of miles.
Dodgy Loner
The food smelled amazing after cooking it on the oak fire. Mmm, rich, smoky, delicious. I may have to grill another meal tonight. I should have enough scrap wood from this project to last me through the year :D
This project should fatten you up  :D.
Dodgy Loner
Yep, I may actually have an incentive to build something with hickory now - just for the scraps :D
I did have grilled hamburgers tonight. Delicious :)
