A very simple log deck
Started by cutterboy, April 03, 2020, 07:42:43 PM
cutterboy
Yesterday I made a simple log deck so I could roll logs up onto my mill.
First I took two oak logs and cut a slab off the top and bottom of the log leaving the log 10" thick top to bottom.
Then slid them off the mill onto the tractor forks and placed them on the ground where they needed to be.
Then I put an old 4x4 on each log and there you have it....a heavy duty functional log deck.
Now, fill it with logs.
In the last picture you can see that the 4x4s are set back 6" from the end of the deck logs. That gives me space to put a 2" thick block on the end of the deck log. Then I place a 2" plank....one end on the block and the other end on the mill to roll logs up onto the mill. The planks are removed after a log is set on the mill.
Now I hope to do some serious sawing.     All the best, Cutter
To underestimate old men and old machines is the folly of youth. Frank C.
KenMac
Looks good to me. Motivated folks can come up with solutions when a problem shows up. Good looking logs, too!
Kinda how I have mine. I have mine a few inches higher, just a few inches. I only have about 2 feet, maybe 16 inches, between the log deck and mil. I just have 2 pieces of metal flat stock, ΒΌ"x4" about 3 feet long to bridge the gap. Important to flatten one side of the log. The logs will roll easier. Good idea on the set back of the 4x4.
