Grizzly Planer: G0544 20" Pro Spiral Cutterhead Planer
Started by Dan_Shade, December 29, 2008, 09:49:48 AM
submarinesailor
Me thinks its time for a short road trip. ;) ;)  Dan is just up the road.  I wonder just how much black walnut and cherry the 250 can carry????
Hey Dan.......................... ;D ;D ;D
Bruce
Norm
Way to go Dan!
I'm amazed they had it in stock. Almost everything I've ever bought from them was on backorder for some time. The last tool I bought from them was my planer. Sure enough they said it's backorder for a month. I said enough of this if you list it you need to stock it, cancel the order. Then about a month later here shows up this semi with a huge crate on it. I couldn't stand to see it sitting there in that cold truck so I brought it home. :D
TexasTimbers
The oil is all in Texas, but the dipsticks are in D.C.
Norm
Yep, but I'm a soft touch....how many of you could turn away a lonely planer. :D
Dodgy Loner
TexasTimbers
Good thing you had not got one elsewhere in t he meantime. Oh well t hat wouldn't be a problem. How many shops have His & Hers planers. You could have painted one pink and enscribed across it Patty's Pink Planer. ;D
Don_Papenburg
You causin trouble Tex . Now Norm will have to buy a new planer and paint it pink
Don_Papenburg
My buddy in the UP has a General 12" jointer with spiral insert cutter . He has had it for five years now . It gets used almost on a daily basis.  He told me that he has changed once . He also said that you will not get to use four sides as the wood will wear on the side of the cutter also .  It may be ok if you do not work highly figured woods like he does . I can tell you that even if you only use two sides of the cutters it would be worth every penny to be able to slide a 10or 12" board over the cutter and not have it beating your hands as the blade makes contact and doing it quietly and effortlesly.
Pecan is killing (has just about killed) my little Dewalt portable planer.  It is on its last legs.  I am going to have to buy a real planer.  Dan, that is a real planer ;D.
TexasTimbers
Don that is an interesting tidbit. Had I known that maybe I should have turned my inserts 180° instead of 90°. Then the wear would be closer to even for the third turn of 90°, and then 180° for the fourth. Theoretically, but it would not work out that way of course as far as dead even wear.
I have to say though, I do not have any lines or weird patterns from just having turned them 90°.
crtreedude
We have both Helix spiral and the Grizzly (the Grizzly is an 8 inch joiner) - and we rotate the inserts, no problems that anyone has mentioned.
A lot of the wood we pass through would never go with a regular head.
So, how did I end up here anyway?
BBTom
It has been my experience that carbide edge will last 10 - 20 times what a steel blade edge will last.  Now multiply that by four sides of the insert and you should agree that carbide inserts are inexpensive.
2001 LT40HDD42RA with lubemizer, debarker, laser, accuset. Retired, but building a new shop and home in Missouri.
Dan_Shade
This thing is nice, I got it wired in yesterday and took a video of the first "full length" board to go through it.
http://www.youtube.com/watch?v=KAhzLBtbR-s
this one is a little shorter:
http://www.youtube.com/watch?v=5uUJbfvJdrQ
lots of dull bands and chains
pigman
Well Dan, I can't see the video until I get to the library since  I am on dialup , but I got to ask, do you like the planer.
Dan_Shade
I wanted to plane every board I had, a complete opposite feeling from using the old delta 22-580!
Norm
Nice! But now I have planer envy. :D
What size of dust collector are you using and do you feel like it was enough?
Dan_Shade
The planer is in a friend's shop, he has a Bill Pentz style clear cyclone with a 5hp (I think) motor on it.
the chips built up in the first video because I forgot to open the gate...  they disappeared after I opened it.  I think the dust collection is adequate, it's running through a 6" pipe to the planer.
the only thing I don't like is the gauge is hard to read, and from what I figured yesterday (need to look at it again), 19 turns of the wheel makes an inch... stupid metric system....
TexasTimbers
Quote from: Dan_Shade on January 11, 2009, 09:14:31 AM. . . .  19 turns of the wheel makes an inch... stupid metric system....
Dan,
I hooked up a spare 1/2" variable drill to my hand crank (cut the two 90s off the handle). Talk about fast.
Dan_Shade
I don't care about the speed, my complaint is 1/19", it would sure be nice if one crank were a 1/16" inch
TexasTimbers
Sometimes ya gotta spell it out for me. I didn't stop to think that 19 turns per inch, would equal 1/19th of an inch per turn.  ::)
It's Sunday. A day of (brain) rest. :)
tim1234
Nice Planer.
I've got the 15" with the spiral cutterhead (GO453Z) and have not used it much yet.  I had dust collector issues.  I had chips coming down on top of the board and getting mashed into the wood by the outfeed roller.  I noticed a little bit of chips at the end of the first video, but you said you didn't have the gate open so I assume that is why you had some chips on the board.
Since then I re-made my home made cyclone seperator top and adjusted fine tuned all the rollers using a dial indicator and the video someone posted about making the little triangle jig.  worked great.  I just got a grizzly dial indicator from my kids for christmas so I don't have to borrow it from work again.
I was getting the lines from the outfeed roller on the planed stock as mentioned on the fist page of your post, but I havn't run a board since I adjusted the pressure on the infeed and outfeed rollers.  Do you see any marks from the rollers?  They are really sharp on the grizzly's.
Tim
Tim
You buy a cheap tool twice...and then you're still stuck with a cheap tool!!
Husky 372XP, 455 Rancher, Echo CS300, Alaskan 30" Chainsaw Mill
Dan_Shade
the outfeed roller has a machined surface.  I've barely used the machine.  I'll report back as I use it more.
Dan_Shade
I've been using the planer for about 12 years now (minus a few years that I had to put it in storage).
It's a nice planer.  It will trip the breakers, but I think I need to rotate the inserts.
Keeping the table waxed helps a lot.
flatrock58
I have that planer and the only problem I see with it is the outfeed roller.  It is a slick steel roller that will slip at times.  I would much rather it be a rubber coated roller
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Brad_bb
I bought the same planer and it arrived first week of January.  Still in the crate though until we get more building materials out from being stored in the shop.
