Equipment trouble anyone?
Started by adirondack harvester, January 02, 2007, 10:33:54 AM
Corley5
Here's some of the issues we've had this late fall/winter logging season.  The coupling that bolts to the crankshaft pulley on the Iron Mule's engine went bad which in turn stripped out the splines in the coupler for the pump and damaged the splines on the pump itself.  New coupler, a nice neighbor with a lathe to make the obsolete part and a new pump and we're back in business. Down time was beautiful weather too.  Get back up and running again for about a week and the mast breaks.  It's a piece of shaft about 6" through and it broke inside the head that the boom and lift cylinder pin to. Another week down for us to disassemble it, have it repaired at the iron works which involved a new shaft, cutting the gears off the old one and welding them on to the new one, welding the whole mess back into the head, $$$$ and us putting it back together.  We ran about another week and decided to replace the bearings in the main articulation pin before it got any worse.  It's the only one the previous owner hadn't done and kept getting worse for us.  We knew it was coming.  We ended up driving the old pin out as far as possible, turning it out some more with a 2' Ridge pipe wrench and 6' of cheater bar (we bent the handle on the wrench), and then cut one part off with the sawzall which took 6 blades, and then ground another part thinner, cut it off with the torch (we couldn't use the torch in the other spot) and drove it back down after we separated the machine.  I got the new bearings which my local tractor dealer had in stock as they are an old Iron Mule dealer  8). They also had the pins which they'd had made.  Cool, got it all.  Got everything lined up with the bearings in place etc, pressed the pin in (maybe pounded is a better word  ;) ;D ) and low and behold it's short by an 1 1/2".  The only way to get it back out was to cut it in pieces also because of the tight fit in the top collar.  We tried a hydraulic jack to push it back out and no go plus pounding on it with and without pressure.  It's hard to lay on your back, hold a big drift pin and swing a big hammer upward ;D and that would've ruined the threads and thus the pin anyway.  So we cut it up and got it out while my neighbor who made the hydraulic pump parts is making me a new pin.  I was going to go to him to make a pin but the dealer had one and I didn't want to make a nuisance of myself either.  He also made a shim for me when I put the new bucket on the machine.  All he's asked for is firewood in payment which is fine.  I always offer cash.  The dealer says he'll work with me on the pin as he told me when I asked that they all take the same pin  ::)  The old pin was 17" overall with 15" of 2 1/2" shaft, an 1 1/2" of thread and a 1/2" thick cap.  The new pin was 15" overall.  I think that all their pins are wrong and whoever made them got the dimensions mixed up.  Luckily we didn't damage the bearings getting the pin back out.  We should have measured it before we put it in but didn't even think about it.  It was the right pin afterall  ::) ::) and the old pin was cut in chunks so there wasn't an easy comparison without laying it out and hindsight is 20/20  ;) ;D  Added to this list is a blown up 372 and a mashed 395.  I'd still rather work on a 30 year old machine than worry about a payment on a newer one
Ron Scott
My logger's equipment problems today were frozen air brakes on the Western Star semi and a cracked clam on the Iron Mule forwarder. The semi then slide down an icy slope on the landing/decking area while loading oak sawlogs and was stopped by a log deck. The slope had to then be sanded to get the semi back up in position. Fortunately the semi carries emergency sand for such occasions.
A normal cold weather day for the loggers I guess, as they blamed their problems on the cold weather. ::)
~Ron
Corley5
Quote from: Ron Scott on January 31, 2007, 07:21:59 PM
That musta made an exciting ride for the guy on the loader  ;D
I got my pin this afternoon and with any luck we'll get the machine reassembled tomorrow.  Shouldn't be too bad as we've already done it once  ::)  Sure would be nice to have a place to work on it inside with heat.  Oh ya we do have such a place but it's full of other projects  ::) ;)  At least we'll get it back together when it's warm.  Supposed to be 23 degrees F  ;)
Ron Scott
Yes he said it was an exciting ride for him. He had his support braces down to and all slid away with him. I had just walked out to the landing from checking the cutting area and wondered why he was in such a position from when I last seen him starting to load.
~Ron
Ed_K
 I was ok till I called my trucker to pick up a load of softwood. He told me that he blew the engine on tuesday, said it'll be next week before he can move some logs. Cost"$180. to move it 3 miles (it was not loaded)and $15,000 for a short block and the mechanic is working on it outside". I bet the price of hauling just went up  :( .
Ed K
