Author Topic: Tension Joinery  (Read 427 times)
Offline barasingha
Tension Joinery
« on: September 14, 2021, 03:28:53 PM »
I have never seen a tension joint made like attaching an axe head and handle by way of a wedge... Why?
If a joint was designed that way would compression perpendicular to the grain be used instead of shear parallel?
Offline JRWoodchuck
Re: Tension Joinery
« Reply #1 on: September 14, 2021, 07:20:02 PM »
There is a lot of wedged mortise and tenon joinery in Japanese timber framing. I know they use that style because itís more conducive for all the earth quakes they have.
Home built bandsaw mill still trying find the owners manual!
Offline doc henderson
Re: Tension Joinery
« Reply #2 on: September 15, 2021, 10:56:57 AM »
I have used blind end wedges on bench legs that were a little loose.  I only use them when needed as they add some complexity.  measuring, calculating and some good old fashioned luck.  I used glue and drove in the tenon and the blind back of the mortice pushes the wedge into the slot as it expands the end.  so if the length of the slot or wedge are off relative to the slack in the mortice, then you cannot get it out for another try.  not to mention estimating the slot width and angle of the wedge.
Offline ajsawyer
Re: Tension Joinery
« Reply #3 on: September 21, 2021, 01:39:49 PM »
I believe the standard for tie beams is the wedged half dovetail: https://www.youtube.com/watch?v=IDKSoCeO8ps&t=310s
If you're interested in timber framing, I highly recommend Steve Chappell's book A Timber Framer's Workshop
Joinery
Started by D._Frederick on General Woodworking
Last post April 02, 2009, 09:05:30 PM
by Dana
axe for joinery
Started by Alexis on Timber Framing/Log construction
Last post February 06, 2010, 08:21:56 PM
by Dave Shepard
3 way post joinery
Started by bigshow on Timber Framing/Log construction
Last post May 16, 2007, 07:17:40 PM
by Jim_Rogers
Joinery detail
Started by FalconFan on Timber Framing/Log construction
Last post July 23, 2016, 08:40:13 AM
by Heartwood
