Author Topic: linseed oil as end seal????  (Read 4005 times)
Offline charles mann
« on: September 16, 2018, 09:18:39 PM »
 any poor side effects of using boiled linseed oil and wax as an end seal?
Temple, Tx
Offline btulloh
Re: linseed oil as end seal????
« Reply #1 on: September 16, 2018, 09:35:14 PM »
Seems like it would work with the right mixture.  Not sure it would save money but it could fill up some spare time.  :)
HM126
Offline teakwood
  • Switzerland
« Reply #2 on: September 22, 2018, 08:49:17 AM »
why the oil?
i know a big sawmill here that uses melted wax to endseal the lumber
Offline GeneWengert-WoodDoc
« Reply #3 on: September 23, 2018, 07:29:38 AM »
The oil will penetrate the end grain and discolor the end of lighter colored woods.  So even though the end might be check free, because the wax slows the drying, significant end trim will be needed to remove discolored and oily wood.  If not end trimmed to remove all the oil, then the oil will interfere with gluing and water-based finishes.
A product like AnchorSeal does evaporate whenever the kiln goes over 130 F, so there is no carry-over into the dry product.
Offline IMERC
  • I have fishin'itis.... Really bad...
« Reply #4 on: September 23, 2018, 08:22:27 AM »
I've heard of used motor oil being used as an end grain sealer... this strikes me as an all around really dumber idea...
what is your take?
Who ever invented work didn't know how to fish.... Here fishy fishy....
Offline PA_Walnut
« Reply #5 on: September 23, 2018, 10:48:27 AM »
I've heard of used motor oil being used as an end grain sealer... this strikes me as an all around really dumber idea... what is your take?
Penny wise and pound foolish. :-X
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline IMERC
« Reply #6 on: September 23, 2018, 11:04:13 AM »
thought as much...
wax it is...
« Reply #7 on: September 23, 2018, 04:40:22 PM »
Does Anchor/end seal have to be reapplied after a few months?
Temple, Tx
« Reply #8 on: September 23, 2018, 05:31:00 PM »
A properly applied (that means thick enough) coating will last a year or more unless heated to over 130 F.
Temple, Tx
« Reply #10 on: September 24, 2018, 08:28:06 PM »
Another popular product (95 % of my clients use it instead of other products) that is widely used is AnchorSeal from UC Coatings in Buffalo, NY.  It can be purchased with or without antifreeze.  It can be applied with brush, roller or sprayer.  The wax melts around 130 F.  It comes in various colors.
Offline PA_Walnut
« Reply #11 on: September 25, 2018, 06:24:10 AM »
AnchorSeal is the bomb. Works great, lots of color options, great people to deal with, fast shipping. What's not to love?
Northland 800 Kiln
Online ljohnsaw
« Reply #12 on: October 09, 2018, 11:22:43 PM »
I picked up a pair of 330 gallon IBCs for a friend to use to hold water for when they do open burns.  These were "very dirty" and free.  They had wax chunks in them along with a milky fluid.  Turns out it is concrete sealer for fresh concrete to hold the moisture in so it can cure.  Its a wax emulsion, probably pretty close to Anchorseal.  I had to use a 3 foot extension on my paint mixer chucked up in my drill to re-constitute it.  I now have 44 gallons and no hardwood to use it on :-\  I'll probably use it on the aspen when I get around to cutting that for my flooring.
John Sawicky
Offline farmfromkansas
« Reply #13 on: December 20, 2018, 07:43:17 AM »
Brought home a couple walnut logs 3 days ago, the ends are still wet.  How long can I wait to seal them?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: December 20, 2018, 08:03:28 AM »
You have already waited too long.  Best practice is to seal them immediately after felling.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
« Reply #15 on: December 20, 2018, 08:13:16 AM »
In general, it is best to seal logs yesterday.  Once checking starts, even if small, it becomes harder to control 100% with proper end sealing.
The coating must retard almost all moisture loss so that the ends do not dry before sawing into lumber.  The coating also must stick to the wood tightly to be effective.  It should be obvious that log ends with sap, dirt, mud, ice or snow have to be cleaned so the end is all wood...that is, it does no good to end coat sap, dirt, mud, ice or snow- -we want to coat the wood!
Offline moodnacreek
  • Sawin by the notches
« Reply #16 on: December 20, 2018, 12:42:06 PM »
If you don't want to spend $, try old latex paint and paper. The idea is to keep the moisture in.
Offline jimbarry
    • WoodchuckCanuck
« Reply #17 on: December 20, 2018, 03:08:06 PM »
Old latex paint as mentioned above. But i was late getting them painted, about a week before I got to painting them.
Been sitting a year now, no end checks.
Come to learn though that red paint apparently contains a lot of mineral. It would spark when starting each cut. Dulled the blades faster too.
Jim
WoodchuckCanuck.com ? Livin' the rural life in Nova Scotia.
Kiln - 2017 Nyle L200, 8ft x 10 ft x 20ft bldg, 3.5-4" 2lb closed cell spray foam, Demilec brand, HeatLok Soya Spray Polyurethane Foam Insulation
Offline jimbarry
    • WoodchuckCanuck
« Reply #18 on: December 20, 2018, 03:21:22 PM »
14 months later
Jim
Offline WDH
« Reply #19 on: December 20, 2018, 04:48:57 PM »
Some species end check way worse than others.  Latex paint, in my experience, has yielded poor results.  Don't skimp if you want quality boards without end splitting and use anchorseal.  There is no instant pudding when it comes to sealing logs.  The right stuff applied immediately after felling is the best way to go.  I have not found a witches brew that works yet.
To seal or not to seal? That is the question.
Started by kevin19343 on Drying and Processing
Last post August 30, 2014, 05:52:57 PM
by BCsaw
Boiled linseed oil BLO
Started by hackberry jake on General Woodworking
Last post February 11, 2013, 08:52:17 AM
by scsmith42
Boiled linseed oil tacky
Started by Brad_bb on General Woodworking
Last post April 21, 2010, 09:17:05 AM
by Brad_bb
Can I glue with linseed finish?
Last post May 20, 2009, 09:05:22 AM
by Reddog
