Yellow pine drying and sterilization
Started by forrestM, May 24, 2021, 08:03:59 AM
forrestM
hello,
I am getting close to cutting some yellow pine (I'm pretty sure it's loblolly)
I'm cutting it at 1" x 6"  and planning to finish to a 3/4" x ~5" flooring for my house.
I am not yet ready to install, but need to cut the logs before they sit much longer, so I am planning to cut and stack directly into my Nile l200m. So I don't get any stain, I am going to dry them to 15% and then take them out of the kiln and let them sit out of the weather. My assumption is that once the wood is down to 15 percent risk of staining, etc should be eliminated if I keep it dry?
Hopefully, in a few months, when I have finished closing in my house, I will put it back in the kiln to take it down to 8%, and sterilize and set the pitch at the same time by taking it up to 160 degrees for 24 hours. Then I'll straighten it and deliver to my friend who will tounge and groove and plane it into my flooring.
I wanted to get some clarification on the pitch setting and sterilization process...with some poplar I have dried, I took it to 15 percent and then turned off the kiln unit, but left the fans running. The next day I came back to unload it and it had gone down to 14 percent. Do I want to stop the compressor and start the sterilization before I get to 8% so that it doesn't continue to dry? Would you do that at like 12 or 13 percent?
Also, do I dry syp at dB 120 and wb 75 like poplar and other group one woods?
I'm in Virginia.
Any advice is appreciated!
Thanks,
Forrest
K-Guy
Hi Forrest
We recommend setting the dry bulb to 160° F , turning the compressor off and when the dry bulb reaches 160°F leaving it for 24 hours for 1" wood 48 hours for 2". If the wood is really sappy leave it longer to cook the pitch even more.
Nyle Service Dept.
- D. Adams
forrestM
Hey Stan,
But you always do that once you've reached final mc? And it doesn't typically cause the wood to over-dry beyond that?
Southside
Can you just sticker it and put a few fans on the stacks? It will be at 15% very quickly this time of year that way. Likely faster than in the kiln.
K-Guy
Quote from: forrestM on May 24, 2021, 08:14:15 AMdoesn't typically cause the wood to over-dry beyond that?
No the compressor is off any drop in moisture content will be from equalization.
Nyle Service Dept.
- D. Adams
forrestM
Is dB 120 and wb 75 the appropriate schedule for
Syp?
@k-guy
Thanks,
Forrest
K-Guy
Nyle Service Dept.
- D. Adams
scsmith42
Be sure to reduce your load size if you dry SYP from green in an L200. Usually I only load 1K bd ft of green syp for maximum drying rate.
If you load too much, the compressor can't remove water fast enough and your lumber will severely mold during the first week or so of the kiln run.
Tom's 3638D Baker band mill
forrestM
forrestM
 Cut my blanks yesterday in the heat and humidity! Stickered directly in the kiln as I sawed, with some extra fans blowing across. I had some little patches of blue stain, and I am hoping a quick kiln zap down to 15 percent will stave it off. I read a lot of posts on how quick it can take over. It was a 12 hour day, and I didn't see the patches spread as I was loading, so that's good. The wood has been in my Nile l200m for 16 hours, has reached 120 dB, and lost about 10 percent moisture already. Avg is between 40 and 50 percent.
Ended up with close to 860 board feet of 1x6 blanks. Had one more log, but wanted to keep the load size low. Should be plenty for my 400 sq ft floor.
Hoping the high heat and humidity in the kiln doesn't encourage the blue stain - from what I've read it should be ok, but I really want clear flooring!
Do you think I should sterilize now, even though I will be drying it down to final moisture in a couple months when I'm ready to install?
Also, for a house with wood heat, and minimal air conditioning, what should my final mc be for Virginia? My plan was to take it down to final mc, remove from the kiln, straighten to 5 1/2 inches, and take to my friend for tongue and groove and then install.
It was my understanding hardwood floors need to be 7-8 percent, but syp doesn't want to be that dry?
Thanks,
Forrest
Southside
You don't want your pine to be below 9 or it will give you problems when it comes time for the millwork.
Also when the MC is that high the numbers you are seeing on the screen are not accurate. So 50 to 40 means things are going in the right direction, but don't take those values as gospel. Get to 28 and then you can be comfortable with the values.
Where will you store the lumber for the next couple of months after it comes out of the kiln?
K-Guy
Once you are at about 15% you have be done with most of the shrinkage, you could machine it then. When you are ready finish the drying to 7-8% and install.
Nyle Service Dept.
- D. Adams
scsmith42
Quote from: forrestM on June 21, 2021, 06:36:39 PM
Thanks,
Forrest
Do not sterilize until the lumber has reached close to it's final MC%.  In most species Sterilizing at too high of a MC% can cause honeycomb inside the lumber.
forrestM
I plan to keep it on stickers, in one of my drying sheds (concrete floor, roof, and open on all sides ) until I'm ready for it.
is it often the case that people will dry to 15, machine, and then finish drying prior to installing?
good tip about honeycomb risk when sterilizing at high moisture content.
a good final mc would be 10 percent with syp?
forrestM
would I be better off storing it indoors, dead stacked?
btulloh
I would dry to the target mc before machining. Then store inside dead stacked. Then the recommended process for flooring is move it where it will be installed and let it adjust to that climate for a week, then install it.
Just reinforcing what was mentioned earlier, i accidentally took a load of syp  down to 5-6 percent that i was using to make shiplap with a chamfer. I got it machined ok, but it was a bit crispy and less than wonderful to machine.  Usable, but less than ideal. I won't be burning the cookies again after learning my lesson.
HM126
Southside
Quote from: forrestM on June 22, 2021, 12:25:32 PMis it often the case that people will dry to 15, machine, and then finish drying prior to installing?
That's not a recommended plan.  You will be surprised at how much movement you will experience between 15% and 9%-10%.  I straight lined a load one time of reclaimed lumber, then finished and heat treated, it in the kiln.  This stuff was ancient and had been at EMC for decades.  Unloading the kiln it was clear to me that I had screwed up. it was an absolute nightmare to run through the moulder.
YellowHammer
Quote from: btulloh on June 22, 2021, 12:47:44 PM
I agree.  It would be like putting the icing on the cake before putting the cake in the oven. Bad things happen.
Yep, once the cookies are burned, they are burned.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
GeneWengert-WoodDoc
I am curious why someone would want to sterilize syp.  What insect is likely to cause damage when at 9% MC?
Southside
GeneWengert-WoodDoc
Indeed, syp is a bit different than most other softwood species.  It shrinks a bit more when the MC changes, but more importantly, it warps when the MC changes.  This warp is due to the grain in the tree, especially the grain angles for the first 15 to 20 years.  Therefore, in addition to perfect stacking when drying, it is also very important to get as close to the final MC as possible. At the same time, drying under about 10% to 12% MC greatly increases machining defects, as the woods getting so much stronger and the grain angle factor too.  Planers, molders, routers, etc. need to be fairly powerful as the MC drops and strength increases.  The bottom line is that it is rare to find syp used for many wood products except structural pieces.
Regarding setting the pitch, for those folks not familiar with the process, the pitch or sap in syp is plentiful.  It consists of many different chemicals.   Some of these chemicals are fairly liquid and runny at room temperature.  Some are liquid at runny at cooler temperatures too. And some become liquid and runny at warmer temperatures.  This pitch can also migrate through paint and even plastic overlays.  The pitch interferes with gluing and also clogs up sandpaper.  It can coat saws and knives.  In the kiln, it can coat the walls.  When syp is used for firewood, the pitch can coat chimneys and create creosote as well, which in both cases is creating a fire hazard.  So, dusting drying, what we do is heat the wood to at least 160 F (180 F is even better and faster) which will evaporate the chemicals in,pitch that are liquid and runny at 100 F and maybe a bit hotter.  After 24 hours at 180 F and around 48 hours at 160 F for lumber under 2" actual thickness, the pitch or sap that remains in the wood will be hard at room temperature.  This process of evaporation is called "setting the pitch."  Should the Wood be subsequently heated in processing (such as heat from machining or sanding, or in a finishing oven), the heat can soften the remaining pitch and create issues when softened.  Of course, when cooled, the pitch hardens.a. Due to this softening, which can happen in a home when the wood is, for example, near a fireplace or indirect sunlight or has a hot pan on it, etc., we generally prefer 180 F treatment temperature "just in case,". Certainly 160 F is adequate. OST of the time.
cabindoc
Scott  aka cabindoc  aka logologist at large
Woodmiser LT35 hyd
Kabota MX5400
forrestM
@GeneWengert-WoodDoc
With syp you don't need to worry about killing bugs? Is that true for ewp as well?
Thanks,
Forrest
