Author Topic: New Router Table Set-up for Slabs  (Read 1314 times)
Offline D6c
« on: July 09, 2021, 06:35:24 PM »
I put this together using the takeonetoo.com router sled kit and a bunch of aluminum extrusion.
Because of limited space I hinged it to the wall to keep it out of the way when not in use.
So far I've only tested it on a couple of pieces, but it seems to work well.
Next up is to put one of my large burr oak slabs on it and see if I can make it flat.
Offline Larry
    • Copas Sawmill
Re: New Router Table Set-up for Slabs
« Reply #1 on: July 09, 2021, 09:37:16 PM »
Outstanding!!! 8) 8)
Tell us more about the sled kit and how to get one.  I went to takeonetwo.com and watched the video....I was impressed.
Hope to see you flatten a slab.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: July 09, 2021, 10:21:19 PM »
thats pretty sweet. I never thought about a chuck extension. That sure could help me on my router sled setup.
Offline D6c
« Reply #3 on: July 10, 2021, 07:18:16 AM »
I got familiar with the router setup from takeonetoo.com through the YouTube channel "Manor Wood".  He's got several videos showing his various router setups and now sells them.  I bought direct from the company.
The kit comes with all the hardware to put together the carriages with your aluminum extrusions.  The parts are all stainless steel and very well made.
I'll post some photos to better show how it's made.
I bought a festool router because it's got a quick release base but it's not as solid as I was expecting.  I ended up having to bolt it down anyway so that feature wasn't an advantage.
I did have trouble getting a router bit extension that would run true enough not to cause vibration.  Most of them aren't high precision.
Offline D6c
« Reply #4 on: July 10, 2021, 05:28:32 PM »
Here are a few pics of the router table.  The oak slab i'm working on it 13 1/2' long and about 40" wide at the widest point.
I have 5 more slabs out the the same log and this one is the narrowest.
The router is cutting real well. I've just about got this side cleaned up.  I may flip it now, clean the other side, then flip it back and finish the first side in case it releases some tension and pulls a little.
Offline Larry
    • Copas Sawmill
« Reply #5 on: July 11, 2021, 05:47:05 PM »
What cutter are you using?  How big is it and are you happy with it?
Offline D6c
« Reply #6 on: July 13, 2021, 09:33:33 AM »
I'm using an Amana 3 flute, 45° cutter  It seems to work pretty well.  There are a couple of other sizes of the same cutter but I don't think I'd want anything bigger.  With the cutter extension it was difficult enough to get it running true so there wasn't vibration.  I ended up chucking the cutter in several different orientations until I got the least amount of runout I could get.
Offline Crossroads
  • let’s make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #7 on: July 28, 2021, 11:31:22 AM »
Nice work! Looks like it works very well
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Lostinmn
  • I was me, but now he's gone.
« Reply #8 on: July 28, 2021, 11:41:01 AM »
That is one of the slickest set up Ideas I've seen, very very nice!
Online charles mann
« Reply #9 on: August 12, 2021, 01:23:23 AM »
Im researching material to to get my sled build to span 74", across my sawmill and use the mill bed for length. just need to find the type of material for the 74" span, that hopefully won't sag any. i was thinking either a set of sbr20 or sbr25 linear rails, of a pair of 1.5x1.5 t-slot extrusion.
Temple, Tx
Offline D6c
« Reply #10 on: August 15, 2021, 05:43:24 PM »
If you get rectangular t-slot extrusion and stand it on edge it should be pretty stiff.
Online charles mann
« Reply #11 on: August 15, 2021, 07:11:20 PM »
So 1.5”x3” and stand it on the 3” end? Could that be the way im understanding you?
I had thought about using a 2 part epoxy type material called ea9309 hysol and filling the 2 t-slots not being used, to help stiffen up and support the long span, but that stuff is like $150/qt.
I think, if im understanding you correctly, it would be much cheaper and more beneficial to take your advise. I will se what mcmaster carr has, the cost and see if i can find similar/same elsewhere for less $$, knowing carr is kinda pricey on some things.
Temple, Tx
Offline D6c
« Reply #12 on: August 19, 2021, 07:11:21 PM »
Yes, that's what I meant....turn it so it's 3" tall.  Can't remember the place I bought my extrusion but will look it up and post it.
You can get inch size extrusions but there are more sizes and acceories for metric profiles.
Offline D6c
« Reply #13 on: August 19, 2021, 07:15:48 PM »
Here's where I got my extrusion.
https://www.framingtech.com/products/
Online charles mann
« Reply #14 on: August 25, 2021, 03:52:21 PM »
i had looked at that site during a google search for t-slot extrusion/framming, before looking at mcmaster carr. like you said, going metric offers much more accessories over standard. I'll be going that way, and using the link you provided.
thanks for the info and heads up on availability of accessories by going metric.
did you buy or build/have built/bent the router support plate/adapter.
it looks like your set up is for a fixed height piece of material, and the only adjustment for depth, is the plunge feature on your router. is that a correct assumption?
i am looking at making an adjustable height feature, for varying thickness of material, ranging between 1" and 6" for a roughing in measurement, then using the plunge feature for finite depth adjustment.
Temple, Tx
Offline burdman_22
« Reply #15 on: September 16, 2021, 11:08:20 PM »
Thats what she said....
Offline D6c
« Reply #16 on: September 17, 2021, 09:59:30 PM »
Sorry for the late reply, I hadn't seen your post.  The router support and other brackets came from Take One Too.
You're correct, it's a fixed height and only uses the router plunge for adjustment.  I could add a riser to lift the carriage to plane thicker slabs.
Planing Slabs with a Router
Started by DR_Buck on General Woodworking
Last post September 23, 2018, 05:27:16 PM
by FLPINERAT
Router for finishing slabs?
Started by Ianab on Drying and Processing
Last post May 08, 2004, 08:59:21 PM
by sawmillsi
Plans for a router jig to plane slabs
Started by brdmkr on Sawmills and Milling
Last post December 06, 2005, 09:08:53 AM
by brdmkr
Router sled for surfacing slabs
Started by Crusarius on Drying and Processing
Last post December 31, 2020, 10:16:27 PM
by Crusarius
