Author Topic: Drying w/ solar  (Read 477 times)
Offline Shutterman007
Drying w/ solar
« on: August 17, 2021, 08:16:16 AM »
Good morning everyone! My friend and I wondering…. Is sunlight important or the resulting temperature? If we use black plastic instead of clear the temp would rise more, thus killing bugs and the sunlight wouldn’t bleach out the wood inside?
Offline JoshNZ
Re: Drying w/ solar
« Reply #1 on: August 17, 2021, 05:13:30 PM »
The wood should never be in direct sunlight, it will be covered by baffles. The collector collects heat and fans pass it through your boards directed by baffles.
I'm sure it would work with black plastic but not as efficiently. Light wants to pass through clear plastic, be absorbed by black material (which your stack is hiding behind), converted into heat and then trapped by the plastic and be put to work.
I guess a black mat left out in the sun by itself would get hot to the touch but the heat it gave off would blow away, unless you trapped it inside a clear container, which it would then heat the inside of.
Offline peakbagger
Re: Drying w/ solar
« Reply #2 on: August 17, 2021, 05:56:06 PM »
I am using black plastic over a stack of firewood. Its on a steel conduit frame with room for air flow on all sides and the base of the stack. If the sun is out it warms right up and there is significant airflow out the vents on the side of the top. One thing is that the wood does not look like its seasoned as its under plastic and the wood does not "cook" so its not gray at all.
Offline GeneWengert-WoodDoc
Re: Drying w/ solar
« Reply #3 on: August 23, 2021, 08:53:08 AM »
Although black plastic will get hotter, you will not be getting all the heat inside the kiln to heat the air that goes through the lumber pile.  Also, the solar drying rate is dependent on how much energy you get into the kiln.  So, a clear cover with the interior painted black will trap more energy.
Ordinary black plastic will deteriorate quickly due to ultraviolet light, high temperatures, and flexing in the wind.  It probably has a life of six months.  Clear lactic or fiberglass oftentimes has us absorbers to slow down the up damage.
Offline farmfromkansas
Re: Drying w/ solar
« Reply #4 on: August 23, 2021, 10:09:29 PM »
I have an old reefer with solar panels to collect heat, using a furnace blower to circulate the heat into the reefer box, and it is dark inside, but uses solar heat to warm the wood.  Good system, just wish I had a couple more solar panels so it would get hotter.  Hottest I have seen is about 120 degrees f. Does get the wood dry, but not hot enough to sterilize.
Re: Drying w/ solar
« Reply #5 on: August 26, 2021, 08:42:45 PM »
Be careful with adding heat to a reefer as the insulation may not be rated for warmer temperatures…it will essentially evaporate into a small pile.
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
solar drying class
Started by steve marek on Drying and Processing
Last post January 24, 2015, 06:43:13 AM
by xlogger
Drying SYP in Solar Kiln
Started by bwstout on Drying and Processing
Last post April 20, 2020, 09:56:43 AM
by bwstout
Drying in my solar kiln
Started by briand7878 on Drying and Processing
Last post September 17, 2019, 04:42:31 PM
by scsmith42
