Author Topic: Wood Storage humidity level?  (Read 303 times)
Offline forrestM
« on: August 26, 2021, 02:28:15 PM »
I have cleared out some space in a climate controlled room for some of my wood because my lumber yard is getting too full. I知 kiln drying some of my pine and poplar lumber down to indoor use mcs. What is the most appropriate humidity level for the storage space. I have hearing and air and a small dehumidifier at my disposal. The would will eventually end up in a climate controlled house with hvac and wood heat. I am in humid Virginia.
Thanks!
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Wood Storage humidity level?
« Reply #1 on: August 26, 2021, 05:04:35 PM »
I run my dehumidifiers in my lumber rooms at 40% humidity which will keep wood at 8% equilibrium moisture content.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline GeneWengert-WoodDoc
« Reply #2 on: August 26, 2021, 08:56:16 PM »
What moisture do you want,  the simple values are
30% RH is 6% MC
50% RH is 9% MC
65% RH is 12% MC
Wood storage humidity/humidifier questions?
Started by Steve on Drying and Processing
Last post May 28, 2005, 08:16:57 PM
by Fla._Deadheader
Advice on... Moisture Content for Cabinet Wood & Maintaining Level in Storage
Started by H60 Hawk Pilot on Drying and Processing
Last post November 05, 2010, 06:35:53 PM
by terrifictimbersllc
Humidity level ?
Started by edsaws on General Board
Last post December 15, 2005, 12:17:14 PM
by edsaws
Proper Humidity for Storage
Started by Stephen1 on Drying and Processing
Last post August 21, 2019, 01:25:10 PM
by YellowHammer
