Author Topic: Blotches on Walnut end grain  (Read 403 times)
Offline ArborGloria
« on: November 04, 2021, 09:12:34 AM »
 I am sanding down a piece of Walnut. The end grain has some dirty blotches that won't sand out. Can anyone identify what the blotches are and advise how to get rid of them. I suspect it might be mould but thought I would be able to sand through it.  Any suggestions?
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Blotches on Walnut end grain
« Reply #1 on: November 04, 2021, 10:11:40 AM »
Are they burn marks from a saw blade?  It looks like that could be it, and if it is, it will sand out with much time and effort on your part.  That is where a drum sander will save your bacon.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline GAB
« Reply #2 on: November 04, 2021, 10:24:42 AM »
WDH:
Congratulations!  This has to be a record.  Got to food in a non-food thread in the first reply.
GAB
Online WDH
« Reply #3 on: November 04, 2021, 11:18:15 AM »
I try.
Online metalspinner
« Reply #4 on: November 04, 2021, 01:47:18 PM »
A drum sander will burn it, too. Need to start with a course grit and enough  feed speed to keep the heat down.
Offline ArborGloria
« Reply #5 on: November 05, 2021, 05:55:44 AM »
Sadly not burn marks.  I have taken it down 2 to 3 mm using 40 grit on an orbital sander and there is no change.  I fear it could be diseased or mould.  I have heard bleach could rid it if its mould but don't want to risk tainting the whole piece.
Offline kantuckid
« Reply #6 on: November 05, 2021, 07:59:28 AM »
If it's not burn marks or mold I've never seen that in lots of walnut I've sawn and used in my shop?
Why would mold permeate all the way through the wood?
Offline ArborGloria
« Reply #7 on: November 09, 2021, 04:56:50 AM »
I've no idea.  I can only guess that mould got to it in the curing process and because it the end grain it has managed to work its way deep into the wood. Could it be diseased?
Preventing dark blotches when staining pine
Started by Fairytale on Sawmills and Milling
Last post August 08, 2009, 08:50:58 AM
by Toolman
face grain vs end grain drying rates
Started by kelLOGg on Drying and Processing
Last post January 24, 2019, 07:50:58 PM
by Don P
End Grain
Started by Fla._Deadheader on General Woodworking
Last post May 27, 2009, 12:44:10 AM
by fstedy
recycled
grain
Started by bad_boards on Sawmills and Milling
Last post August 30, 2006, 08:14:29 AM
by bad_boards
