Author Topic: Air drying old cherry  (Read 1243 times)
Offline maple flats
  • Life is what you make it!
    • cnymaple.com
« on: April 30, 2005, 08:40:31 PM »
What is everyone's suggestion for air drying cherry? The logs have been on the forest floor in a high area about 10 years and now that I have a mill I am cutting to recover before it is all rotted. There is anywhere from an inch to 2.5 " rot on the outside but the rest looks remarkably good. I want to air dry it before trying to sell it. Do I put it in the sun or shade? Do the stickers need to be cherry to minimize staining or can I use hemlock? How high off the ground for the bottom of the stack is recommended? I will be making a stack about 30" wide and putting a piece of steel roofing of 37" over it.
Offline Ianab
Re: Air drying old cherry
« Reply #1 on: April 30, 2005, 08:57:59 PM »
If the logs been down that long it will be pretty dry now anyway, just need to be stacked up for a while to complete the air drying.
How high of the ground? - 12" should be OK, you just need to let air circulate under the stack, and be up out of the grass / or dirt splattered by the rain.
Shade - I'd go for the shade with the hardwood.
Stickers - Anything as long as it's dry. Dry hemlock will be better than wet cherry.
Sounds like you have things under control  ;)
Cheers
Offline maple flats
    • cnymaple.com
« Reply #2 on: April 30, 2005, 09:23:21 PM »
Thanks Ian, that's about what I thought but knew there were much more experienced members out there.
Maple
Drying 8/4 cherry
Started by Rugby on Drying and Processing
Last post January 20, 2007, 08:43:51 AM
by Rugby
Cherry Air Drying
Started by CEaston on Drying and Processing
Last post December 15, 2019, 03:09:31 PM
by Jeff
Drying Cherry
Started by D6c on Drying and Processing
Last post October 21, 2021, 01:51:54 PM
by Stephen1
Air Drying Cherry
Started by E-Tex on Drying and Processing
Last post April 01, 2018, 01:03:07 PM
by GeneWengert-WoodDoc
