Author Topic: air drying  (Read 3985 times)
Offline jimmy
air drying
« on: February 16, 2004, 07:02:29 AM »
I would like to know the best way to stack your lumber for outside? How far apart to put your stickers? Should your stickers be dryer then the wood your stacking?What size should your stickers be? As you can see i'm new at this. I would appreciate any help.
Re: air drying
« Reply #1 on: February 16, 2004, 07:15:41 AM »
General Rule of Thumb
Stickers 1"x1"x8
put stickers within 3" of the ends of the boards and 18" intervals
Line stickers up to form a column. crooked column's mean crooked boards.
Use dry stickers
Put an air space of at least 1 foot beneath the stack
A stack 4 to 6 feet wide provides the best air flow.
Don't exceed 8 feet wide.
Cover stack with a roof that does not hang over the sides.  Do not drape a tarp over the stack.
A pole barn makes a good drying shed.
Do not allow the sun to directly cook the wood
Do not stack against walls or in corners or up against other stacks
Here is a good picture of a stack that member Brian Baily consructed
https://forestryforum.com/cgi-bin/board/YaBB.pl?board=sawmill;action=display;num=1054741061;start=4#4
Search the forum too. There is quite a bit of conversation about air drying wood.
Offline Brian_Bailey
  • A Great State to be From!
    • baileyswoodworking.com
Re: air drying
« Reply #2 on: February 16, 2004, 11:53:07 AM »
Thank you Tom for linking to one of my pictures.
The pic is kind of misleading as it appears that the stickers are set in from the ends of the boards. There are stickers at the very end of the boards, this is important because it will keep end checks from getting started or getting worst ( most times  :D ).
Tom is correct in that you don't want to cover a stack of lumber with a tarp. You want the air to flow thru it. The air is what carries the moisture away from the lumber surface and hastens the drying process.  But, you need to control the air flow, so that is why I use tarps on my piles. What I really need is an air drying shed, so I can get rid of those ugly tarps  :D.
The links below have good info on stacking lumber.
http://www.fpl.fs.fed.us/documnts/usda/ah188/ah188.htm
http://www.fpl.fs.fed.us/pubs.htm
WMLT40HDG35, Nyle L-150 DH Kiln, now all I need is some logs and someone to do the work :)
Offline Den Socling
  • just wondering
Re: air drying
« Reply #3 on: February 16, 2004, 02:17:50 PM »
Air drying yards used to put a corrugated metal roof on top of the stack. I now see them using slabs of concrete.
Shade cloth is like a tattered tarp. It blocks most sun but lets most air through.
Offline AtLast
  • Dis-member-ed
Re: air drying
« Reply #4 on: March 03, 2004, 03:28:27 PM »
Ive been very very fortunate with air drying. On the other hand my Dad has not seein as it's his garage I store the lumber in  ;D BUT like Tom said and showed in the pic  link. there really really is a right and wrong way to do it.
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
Re: air drying
« Reply #5 on: March 03, 2004, 05:47:58 PM »
Anybody use Shade Dri (www.shadedri.com)? It is only 14cents a square foot and looks like it does a good job.
Offline dewwood
  • Makin sawdust
    • Powers Hardwoods
Re: air drying
« Reply #6 on: March 04, 2004, 03:23:42 AM »
I have been using shade dri for over a year now and it seems to be working quite well.  I have it on the back side of my drying shed.  It cuts out most of the sunlight but still allows air flow.
Dewey
Selling hardwood lumber, doing some sawing and drying, growing the next generation of trees and enjoying the kids and grandkids.
Offline shopteacher
  • Hiking Sedona, AZ.
Re: air drying
« Reply #7 on: March 04, 2004, 04:30:21 AM »
That looks like a great product. I'm going to check into that a little further. Thanks for the heads up Oakie.
Offline oakiemac
    • Hickoryandoak
Re: air drying
« Reply #8 on: March 04, 2004, 05:59:48 PM »
You are welcome. I'm definately going to get some.
Offline BW_Williams
  • Part time sawyer, East slope of the Cascades
Re: air drying
« Reply #9 on: March 04, 2004, 10:08:35 PM »
I like to have the end stickers right flush with the ends, we have real dry summers and I believe this helps with end checking, as does Anchor Seal.  BWW
Support your local Volunteer Fire Dept.  (not by accident)
Support your local Ski Patrol (by snowboarding:)
Mayor of Millerdale, Washington, USA (by God)!
Re: air drying
« Reply #10 on: March 05, 2004, 05:41:35 AM »
Here's a thought,
If your boards have trimmed ends or are fairly straight across.
Try using a wider sticker on the end of the stack and leave about 1/2" to 3/4" over hange the end of the pile.
This does a nice job of shading the ends from the sun.
Offline cozynest
Re: air drying
« Reply #11 on: March 05, 2004, 03:50:13 PM »
Brian that is some nice stacks of lumber you have pictured. Bet all you want for Christmas is a drying shed to hold that lumber before it goes into the kiln. ;D
If you don't mind me asking, do you sell your dried lumber wholesale or retail . Just seemed a lot for retail.
Steve
LT27G18; Kubota 3710
Re: air drying
« Reply #12 on: March 05, 2004, 08:02:49 PM »
Hi Steve,
Your right, only I could really use a drying shed a lot sooner than Christmas :D :D.  I'm hoping to get one up this year  :D, I've only been saying that for the last 15 yrs or so !  :D :D
Thanks re the stacks. They're fun to build and take pictures of  :).
The only downside is, it takes a long time to build them that way. It wouldn't be practical if your sawing a lot of bf daily and working by yourself.
I don't sell wholesale, just retail.
What I don't sell outright gets used in my woodworking business.
My operation is just a hobby business ( my accountant warned me to never use the word hobby publicly :o ) that gets a little out of hand at times  :).
Offline cozynest
Re: air drying
« Reply #13 on: March 06, 2004, 11:03:40 AM »
Thanks for the info Brian. I too am a woodworker. I've been retired for three years now and I'm finding this hobby is starting to get out of control. My accountant says I better watch it as there's no return in a hobby. Pun intended :)
Keep up the good work!
Thanks,
Steve
Offline BW_Williams
Re: air drying
« Reply #14 on: March 06, 2004, 12:41:02 PM »
Good idea about the wide stickers on the end, Brian unfortunatley, I usually find that my chainsaw had cut the logs crooked, so those end stickers may be alot of bf!  :D
