Finally, I'm Committed
Started by TroyC, June 16, 2022, 10:03:02 PM
TroyC
Well, some people think I actually should be, but after a year of planning,  finally got some post in the ground today for another sawmill shed. Not going fancy, just a basic cover to get out of the sun.
Did I mention how hot it was in central Georgia today? It was HOT.
<Got 5 out of 6 post in today. One more in the morning before it gets hot.
TroyC
6 posts up, tops marked for cutting to height. Gonna get those 20' beams up tomorrow!
customsawyer
www.thecustomsawyer.com
Good to hear.  When I saw the title, I was concerned that they took you away in a straight jacket.
TroyC
10-4 on the shade! Brutal outside after 10 am or so.
TroyC
Beams going up today.
Took little ones fishin' last evening.
barbender
I like the last picture, the best. It's way too easy to let that slip away!
47sawdust
What keeps the beam from rolling off the forks ?
Mick
TroyC
Forks have a slip on channel on the ends with  a 6" angle iron holder. Strap the beam  tight to the angle with ratchet straps. Set beam then lower forks carefully and they slide out of the holders.
Beams set. Now gotta find a couple trees for the rafters  8).
Southside
Quote from: WDH on June 18, 2022, 07:38:50 AM
No worries here, they don't let you have internet access when that happens, or so I have been told.   :D
White Oak Meadows
That fishing picture is great!!!
Looks like he has a big one on there!!!
Congrats, those beams are looking good up there.  Nice work !!  8)
kantuckid
Is that a TYM tractor? Can't see the brand name. I've got a new Branson which is a twin company machine.
I bought two fork extensions on a scratch and dent buy off amazon-They are Titan made. They are to extend my FEL forks to raise wall logs.
 I'm interest in those gizmo's on the tips myself.
I was thinking two short sling straps using a clevis or other holding setup for a wall log?
Yesterday I picked up my used Genie, crank up lifting device-it would do that beam job with ease-up to 650lbs. It's place to earn its keep is spots to small for a tractor. They are designed to go through any regular doorway.
TroyC
Yes, a TYM 474 hydro. I really like it, just the right size for me. Had a 394 and sold it, the 474 is 10 more HP, 4 cyl, if it won't do it I probably shouldn't be trying.
I'll put a pic up this evening if my simple homemade log holder that slides over the fork tips.
Got 5 full size 2x10x23' from one 22" log. Done for the day, cooled off nicely, only about 92 or so. Fishing tonight after a big steak dinner 😋🍺
TroyC
Here is the fork holder for the beams. Just a piece of channel with straps that slip over fork ends. Yellow angle us the support and I strap stuff to the angle. Tighten the bolt for stability or leave it loose and the forks can slide downward for easy release.
Fishing was a little slow but we did manage a turtle. He was glad to get back in the pond.
I bet those boys enjoyed that.
TroyC
Standing to lumber, 2.5 hrs. Almost have all rafters cut.
I bet somebody's clothes got sticky :)
Cornerstone
Those boys will never forget this experience. I bet you won't either. I look forward to grandchildren.
Case 580SK backhoe, New Holland L228 skid steer, Kubota 900rtv, Home made band mill, 1968 Chevy C50 Dump Truck, 1972 C10, 2009 Dodge Ram 3500 4X4 dually, all sorts of motorcycles.
Ephesians 3: 17-21
TroyC
Rafters up. 105 in the shade today. I'm toast. Young ones stayed in the A/C most of the day, too hot to fish. They did ride golf cart (again) after it cooled to around 90. They spotted the two fawns yesterday and a couple rabbits today. They don't get excited seeing turkeys anymore. Baby bird flew the nest this morning also.
I like the No Snow Load roof ;D.  Our heat does not weigh as much as the snow and ice in the Glaciated North.
TroyC
So true, I'd rather shovel sunshine than snow!
Looking mighty fine Sir!!  8)
TroyC
Thanks MM, purlins today, metal will be here tomorrow!
TroyC
Purlins up, metal went up yesterday.
Pretty much done! Gutters and some trim next trip to the camp.
