Author Topic: Ash borer  (Read 439 times)
Offline bitternut
Ash borer
« on: January 16, 2021, 06:23:45 PM »
I live in Niagara County NY which is loaded with white ash trees infested with the borers. There are a couple of trees near me that are infested that I would like to cut down. I would like to conduct a little experiment to see if the larva would die if the trees were chainsaw girdled now and then cut down later in the summer when it is much drier. I don't want any bugs to escape. I would like the buggers to stave.
Would the trees die quick enough in the spring to kill the larva? ???
Offline square1
Re: Ash borer
« Reply #1 on: January 17, 2021, 06:03:02 AM »
Short answer: No
Long answer: Early science indicated EAB was attracted to distressed Ash trees.
One method employed to detect the presence of EAB was to girdle (cause distress to) select trees  spaced across a wide area in the spring / early summer. The crew would return the following late fall / winter, fell the tree, and strip the bark using draw knives, examine the cadmium layer, and collect larvae if present. Finding live larva was not uncommon.
Ash borer is here
Started by D6c on Forestry and Logging
Last post June 30, 2019, 03:00:09 PM
by barbender
Ash Borer
Started by phatboy on Sawmills and Milling
Last post April 07, 2016, 09:50:36 PM
by woodman58
Ash borer
Started by welderskelter on Sawmills and Milling
Last post May 08, 2021, 10:05:49 AM
by welderskelter
Borer treatment
Started by JoshNZ on Drying and Processing
Last post February 08, 2018, 04:46:43 PM
by JoshNZ
