Milling For Hire
Started by BigTX, March 15, 2024, 02:38:11 PM
WV Sawmiller
Quote from: doc henderson on March 27, 2024, 10:37:38 AMHoward, you should see my first bench I made with the first practice log I sawed when they brought my mill. :uhoh:
If you'd like I can show you haw to put it back on the mill and make the legs all level. ffcheesy ffcheesy ffcheesy
doc henderson
You do not understand Howard, you would have to change the angle ect, and even you cannot do that well on a sawmill.  I was going to say you are probably the leading expert on fixing crappy benches,  :uhoh:  but of course that is not true and seemed a little too mean, even for me.  :snowball: all in fun!   ffsmiley
If it will make you feel better, I will take a few pics.
doc henderson
OK, you asked for it.  I have made prob 200 benches since these first two.  they serve as a reminder.  that is why I do not fix them.  yes, I needed better back up for the through mortices.  that is why I do not do that anymore.  the angles are more uniform with my radial drill press setup.
a little stack of benches I have kept.
a little three-legged bench #2
my first bench.  crooked legs and all.   ffsmiley ffsmiley ffsmiley
doc henderson
