Log Identification
Started by Mossy Chariot, December 23, 2019, 12:35:01 PM
Mossy Chariot
Will someone identify the log I am preparing to saw?  Thanks for your help!!!!
Tony B
LT35HD, Riehl Edger, Woodmaster 725 Planer/Molder, Nyle 53 Drying Kiln, WM BMS 250, WM BMT 250, T750 Bobcat, E50 Excavator, Kubota 3450, Wallenstein Skidding Winch, Vermeer BC1250 Chipper, Stihl 250 & 460, Can-Am Defender
stanmillnc
The square bark pattern indicates Persimmon to me. You'll know once you start sawing it - if it's hard as a rock, it's Persimmon!
Larry
Black gum.
Wait for WDH to give the correct answer!
Southside
That or Tupelo came to mind.
White Oak Meadows
Pretty sure that it is persimmon.  One way to tell for certain between persimmon and blackgum.  Persimmon is ring porous or semi-ring porous.  Blackgum is diffuse porous.  A close look at the end grain will give you the answer.  Or, take a razor knife and make a clean slice on the end grain so that you can clearly see at least three or four growth rings, take a close-up pic, and post it here.
Another clue is that dark/black pith.  That is what you would see in persimmon.  I do believe that it is persimmon and I want it!!!
DPatton
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
stavebuyer
After sleeping on it, I wouldn't argue with you about that as the knobby bark is also seen on upland blackgum.  Persimmon bark is typically blacker than what is in the pic.  However, the ring structure will be the deciding factor.
stavebuyer
The green moss growing in the bark is also characteristic of black gum. Persimmon usually has a much more uniform bark pattern that runs more to black.
timberking
I can go either way.  I see both but my first thought was persimmon.
Mossy Chariot
Here are a few pictures of a cross-section sliver. Could not get the camera to focus close up. These are under a magnifying glass.
Tony B
I believe that the blackgummers have it.
Mossy Chariot
Thank you guys. It seemed a little on the soft side, relatively, when I sawed it. Hope you all had a wonderful Christmas!
Tony B
123maxbars
see much of that down in Knoxville? Don/t see much up here @Mossy Chariot
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Mossy Chariot
No not much Nathan @123maxbars   This is the only one I've seen on my property. I've seen one on a neighbor's property as well.
Tony B
