Author Topic: Hood tagalong slasher issue  (Read 403 times)
Offline taurus
« on: August 06, 2021, 03:45:16 PM »
My buddy bought a hood tag along slasher.. the blade is not running fast enough.. it stops in the wood. how do you make the blade turn faster?  thanks
Offline mike_belben
  • Pulp Friction
Re: Hood tagalong slasher issue
« Reply #1 on: August 06, 2021, 06:05:43 PM »
You find out where the pressurized hydraulic oil that gives the saw sufficient torque to tear fiber is bypassing before it does its work.  If it has a case drain port put the drain hose in a bucket and see how much volume is coming out. Thats oil not doing work and it shouldnt be a lot.
Isaiah 63:10
Hood slasher
Started by loggerman1959 on Forestry and Logging
Last post July 11, 2021, 10:28:10 AM
by cutbank
Hood Slasher problem
Started by adirondack harvester on Forestry and Logging
Last post November 01, 2008, 08:49:31 PM
by Reddog
CTR 40/42 slasher
Started by treefarmer87 on Forestry and Logging
Last post June 05, 2010, 07:21:48 PM
by treefarmer87
Bar saw slasher
Started by jwilly3879 on Wanted
Last post January 10, 2014, 03:43:23 PM
by jwilly3879
