Author Topic: Tree Farmer C7E Query  (Read 687 times)
Offline Koopsy
« on: September 15, 2021, 09:43:19 PM »
Hello, I've recently purchased a 1980s Tree Farmer C7E and I wanted to change out all the fluids and filters. Would anyone know what kind of engine/tranny oil this machine would take? I'm up in Northern Ontario where the winter drops around -30'C in January and the summer peaks around +30'C in July.
The machine has a Cummins engine, Clark Winch, and a Clark 3 speed powershift.
Any information about this machine would be appreciated.
Bobby
Offline Koopsy
Re: Tree Farmer C7E Query
« Reply #1 on: September 15, 2021, 09:45:03 PM »
Offline thecfarm
« Reply #2 on: September 16, 2021, 07:59:27 AM »
Welcome to the forum.
Working it full time in the woods or just for your own use?
Like the place to hook a chain in the middle of the blade.
Looks like a delimber on the side of the blade.
Offline Koopsy
« Reply #3 on: September 16, 2021, 11:27:51 AM »
Thanks. It's for my own personal use on my property.
I believe it's good practice to change most fluids when purchasing old iron.
I presume it's an accumulator on the blade. I've never seen one before, not sure what its specific purpose is.
Bobby
Offline Koopsy
« Reply #4 on: October 10, 2021, 03:29:15 PM »
It turns out I have a Cummins 6BT, Clark 3 Speed Power Shift, and a Clark Winch.
Should I run 5W-40 in the Cummins, to accommodate summer and winter?
What oil does Clark PowerShift use?
Should I run AW-32 or AW-68 hydraulic oil?
Thanks in advance,
Bobby
Offline barbender
« Reply #5 on: October 10, 2021, 04:08:07 PM »
I would run a good quality 5w-40 synthetic, I like Rotella in the blue bottle. That's what I run in my Cummins B series engines. I can't tell you what for the tranny etc. That's a sharp skidder, looks like it was well taken care of.
Offline barbender
« Reply #6 on: October 10, 2021, 04:14:59 PM »
Ok, one more. I'd say a aw46 hydraulic in the summer, and an aw32 in the winter. If you don't want to be changing it seasonally (I wouldn't) there are premium hydraulic oils that stay thin in the winter. I run Ponsse equipment, we had been running a Petro-Canada/Petro-Choice iirc and then Ponsse started getting a Ponsse label on it so I can't remember for sure what it was. I believe it is an aw46 with a very wide operating temperature range. We used to dump our hydraulic oil in the fall and switch out to an aw32, we don't have to with this oil. It's really more of a "performance" oil than you need, but if it saves you from the seasonal switch then it would be worth it. I think we pay around $20/gal US for it.
Offline snowstorm
« Reply #7 on: October 10, 2021, 06:34:57 PM »
15 40 in the motor what I run in everything. My Clark trans Mercon   ATF. Clark says that or you can use motor oil
Offline snowstorm
« Reply #8 on: October 10, 2021, 06:38:07 PM »
The grapple on the blade is to pick up the tree that came un hocked on your last trip or to per bunch
Offline Koopsy
« Reply #9 on: October 12, 2021, 06:32:23 PM »
Awesome, thanks again.
Would anyone know what kind of oil goes into the wheel hubs?
Bobby
Tree Farmer C7E
Started by Oliver05262 on Forestry and Logging
Last post June 05, 2019, 02:37:05 PM
by Autocar
Tree Farmer c7
Started by Fether Hardwoods on Forestry and Logging
Last post January 19, 2016, 10:08:45 PM
by Logger RK
Help with Tree farmer C5
Started by BCWoodsman on Forestry and Logging
Last post September 22, 2019, 08:04:53 PM
by jdatwood
Tree Farmer ?????????
Started by Autocar on Forestry and Logging
Last post October 17, 2011, 03:54:31 PM
by mad murdock
