Sawing Straight and Fast
Started by YellowHammer, September 29, 2022, 01:28:19 PM
YellowHammer
Here's a video lots of people have been asking for, how to saw straight and fast, and how to not leave sawdust on the board.
Sawmill Secret! How to Saw Straight and Fast! Learn From a Pro! HHA - YouTube
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
jpassardi
Another informative video - nice work YH. smiley_blue_bounce
OlJarhead
I was just about to post this in my thread!  and I will still ;)
In fact, I link to it in my next video (tomorrow)!  Fantastic video YH!
Resonator
Learn from a pro, class is in session!  smiley_book2_page
Will be watchin for that rooster tail from now on! smiley_thumbsup
Ljohnsaw
Great video.  I'm on the opposite side of my exit but I'm gonna be looking now, somehow!
John Sawicky
terrifictimbersllc
Nice video. How do you check that exit deflection if you're at the far end? Can't really back up the band with the dragback fingers down.
Walnut Beast
Nice video! Didn't like the anti Don Bacon ad though 😊
Dan_Shade
lots of dull bands and chains
YellowHammer
Quote from: Walnut Beast on September 29, 2022, 04:49:39 PM
?? Unfortunately I have no control over the adds, I don't even know which are played.
The exit deflection is easy to hear or see, as the band will make a "boink" sound and will jump noticeably when there is deflection at the end of the cut.  This can be seen even from the opposite end of the sawmill.  Actual, it's pretty easy to see if you watch the glint of the blade just as it exits.  I watch out for the jump on every cut, as as soon as the band exits the cant I do a dragback anyway.
YellowHammerisms:
Good video, and basic good information.
I use Adblock Plus and do not have to look at ads.
Larry
Excellent camera work following the blade and the rooster tail!  Thanks for taking the time.
I find using the 7/39's they saw fast and clean out the sawdust.  The regular 7's saw slower and leave lots of sawdust but the redeeming quality is the cut is super smooth.  I think I like fast and no sawdust best.
Andries
Thank you, again, for producing such a fine video.
The "bad chicken" clincher is terrific. I tend to get task oriented and tunnel visioned when milling. "Just two more logs!" Then spend time on the bad cuts with the jointer and planer.
LT40G25
Ford 545D loader
Stihl chainsaws
Peter Drouin
Just back the blade up without lifting the head. If it hits the log you're off, If you see light under it you're off. Without a drag back down. A lot of mills don't have one.
Roster tails are good to look at too.
Cut take the board off leave the head where it is and backup watch the blade coming back will tell you a lot too. With the washboard,
The set is off of your cutting too slow. Cutting logs with no knots [clear] will cut nice.
Nice video YH.
A&P saw Mill LLC.
License NH softwood grader.
customsawyer
Seems like we've had this conversation before. Good video.
www.thecustomsawyer.com
moodnacreek
Sawing really fast requires precision that most don't understand or have time for. That's why the real mills have a professional saw filer.
Cornerstone
Nice work Yellowhammer! I really appreciate you telling me what to look for to make me a better sawyer.
Case 580SK backhoe, New Holland L228 skid steer, Kubota 900rtv, Home made band mill, 1968 Chevy C50 Dump Truck, 1972 C10, 2009 Dodge Ram 3500 4X4 dually, all sorts of motorcycles.
Ephesians 3: 17-21
SawyerTed
Quote from: moodnacreek on September 30, 2022, 08:35:49 AM
And why good filers make as much or more than anyone else in the mill.
Stephen1
I always change my blade when I see the movement as it exits the log. It is my 1st sign the blade is dulling. I change the blade unless I am taking the slabs off of a Big pine with ugly bark. I will do all 4 sides then change the blade.
By the way good video!
boonesyard
Great video, I never paid attention to the angle of the rooster tail before.
Sawed up 562bf of white oak last night and paid attention, very interesting. I started with a blade that had about 300bf on it and after a bit, I noticed the rooster tail was wide, spread out. Was still sawing straight but the engine load was climbing. Changed the blade and the rooster tail was a fine straight stream, engine load dropped by 10% at the same feed speed. Great stuff!
Thanks YH
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Hilltop366
Starts in D for a second and then goes up to Eb (E flat) or really close.  smiley_guitarist
YellowHammer
Nice.  I love the sound of a good band in the morning!
The bad chicken thing just popped in my head, but sometimes it's best not to cook a stinky chicken!
YellowHammerisms:
barbender
If I didn't already say so, great video Robert. You've done a great job editing on the few I've watched.
Today was the first time I've had my saw fired up since watching this video. I put on a new band, rolled on a big knotty pine, and went at it. As it turns out, my rooster tail is rising out of the cut, and the band is resonating an E below middle C. The E I can live with, the off center roster tail is going to drive me crazy now that I know about it. Thanks Robert😑😂 Looks like I'll need to check by guide wheels etc to see why it's off center.
Cjross73
Very informative,  thank you for sharing
LT40, Stihl saw, Old green tractor
tacks Y
Ditto on the video.
I end up with saw dust on a lot of my wood, thinking I am going to slow. I am never in a hurry putting on sticks as I saw. Do you think increasing my speed will clean up my boards?
Dan_Shade
I think running with a high feed rate is easier to do with plenty of horsepower.
My saw has a 25hp engine, I don't think I can drive the band hard enough to not have sawdust left in the kerf.
