Any ideas on what this is?
Started by Nomad, November 17, 2019, 12:24:20 PM
TKehl
Definitely try the magnet test.  That will tell a lot quick and easy.
I don't work in a scrap yard, but do run a metallurgy lab.  When asked how big, I show them a bit that is half the size of a BB and say that I can work with smaller, but it is fast and easy if it is at least that big. Then I can use the handheld gun instead of the scanning electron microscope.
I doesn't harm the sample to take a surface reading.  You shoot it with some X-Rays and the meter looks for the energy decay signature to determine the element(s).  (I mostly work with alloys.)  Takes about 5 seconds for most metals.  If I have to grind/polish to get through rust, carbon, etc. to get to metal, that is the only harm done.
markdvsmo
Meteorite!
(I'm only half kidding.  Could happen.)
Nomad
     One of the first things I did was check it with a very powerful magnet.  It is non-magnetic.  Sounds like it's plenty big enough to test it.  No way this thing was ever fired from a gun.  Much too hard, and the shape is all wrong.
     Non-magnetic, barely reads on a metal detector, black, too hard to scratch with a file...  I'm wondering if it could be a piece of stone?  Shattered on three sides and the rest is a rounded surface, like the tooth of a gear.  Would be an oddly shaped stone, but possible I suppose.  Or maybe a piece of ceramic?  I'm mystified.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Chuck White
If the piece you were resawing had been in a welding shop or was loaded on a truck or trailer, it could possibly be a piece of welding slag!
When a welder was chipping away some of the slag, it could have launched some distance and then being hot, imbedded itself into the wood!
Just a little thinking "outside the box"!  ::)
Nomad
Chuck, that's as good a theory as anything else I've heard, or come up with myself. :D
Lucas DSM23-19
Nomad
    I believe I've figured it out. 8)  It is a piece of stone.  A piece of flat, water eroded stone like you'd skip across a creek or lake.  The profile matches perfectly.  How it got there?  I dunno.  Maybe the timber got dragged across some, or run over by a truck or something.  Need to find a mineralogist to verify that.
Lucas DSM23-19
Normang
Nomad
Lucas DSM23-19
