Cut some GUM today
Started by yarnammurt, January 12, 2015, 03:46:18 PM
yarnammurt
With he price of gum I thought I would thin the wood lot out. Right now its $60 ton for nasty gum logs. Should be 12-14 ton, Last one I hauled was 14 and some change.
ATS 10" Peterson, 09 New Holland 4x4 TL90 with loader, 125hp White,2 2009 Kawasaki 610 mules,
POSTON WIDEHEAD
Thats a load.  :D The tires are grunting!
Poston wants to cut some siding from that  ;D.
POSTON WIDEHEAD
Quote from: WDH on January 12, 2015, 03:56:08 PM
It would make some DanG good barn siding.  :)
fat olde elf
What is god siding ? for a church ?
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
POSTON WIDEHEAD
Jemclimber
It's a tough crowd for the goat. Always someone waiting to pounce.  :D
lt15
Herb Brooks
Quote from: Jemclimber on January 13, 2015, 11:11:53 AM
Kinda like coyotes ain't they
POSTON WIDEHEAD
You're right Jem......one day I'm gonna fly off the handle and clear out some of these threads.  :D :D :D :D
I have Goat friends in high places.
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
Alligator
Esterer Sash Gang is a  Money Machine
lawnsbylane
Why not saw some cross ties out of them ??? is it worth more as chip or what
yarnammurt
Sweet gum, And it is going to a tie mill. I have 3 more loads 8)
dean herring
Saw some gum lumber on another post, it looked good. But not knowing if it will be I am asking.
Failure is not an option  3D Lumber
dean herring
Going to have a BIG sweet gum cut that is close to our house. Should I save it to cut when I do get my mill?
pineywoods
Dean, I think you will find that sweetgum logs don't store very well. Best to saw into boards as quickly as possible.. Oh, and quartersaw it. Stack and sticker well, plenty of weight on top, and cover with roofing tin.
reubenT
yup.  That microbial life sure loves munching on it.   I sawed railroad ties for awhile,  picking them up and stacking them by myself got old.     The biggest piece of steel I ever hit was in the middle of a black gum.   Some guy was plowing the mountainside field long ago an lost a mule shoe.   hung it on the branch of a sapling.     When I hit something real solid in there,  was making 2x8's for my shed,  didn't want to loose the board so turned the log around and sawed in from the other end close to the object and split the board off.   I still have a rafter in the shed roof with the mule shoe buried in it.
fishfighter
Is gum any good to make stickers? I have a few I need to clear cut. They are on the small side. If they are not good, I will just pile them up and burn them as I did in the past.
They will warp and twist unless quartersawn.  But, if you quartersawed it, I wouldn't use that for stickers  :).
terrifictimbersllc
Or a troll under the bridge.
p.s. here it is, with even more stories about goats!   http://www.pitt.edu/~dash/type0122e.html
fishfighter
Thanks for the heads up about using them for stickers. Burn pile they will go. :D
dean herring
Thanks for the info. Think I  will just let that gum live a little longer.
All the spiral grain woods like sweetgum, blackgum, sycamore, elm, and hackberry are very difficult to deal with.
