Band Blade Selection
Started by Shawn, February 24, 2006, 12:54:24 PM
Shawn
I see that Cooks Saw has 4 manufactors for band blades. Simonds, Lenox, Munkforssagar & Tech Band. They are all within 50 cents for the same size. Is any one better than the other?
Shawn...
Change is part of the design process.
Admit nothing, Deny everything, Make counter-accusations
Fla._Deadheader
Try one of each  :) :) ;D ;D   We prefer Munks.
Check out Menominee Saw, one of our sponsers over on the left of the page.  They distrubute blades, weld bands, doctor saws, etc., and are a lot closer to you.  You will probably save a bit on UPS shipping charges.
chet
Not ta mention handle three of da brands ya mentioned.  :)
Dan_Shade
i use monks from minomonee great folks to work with!
lots of dull bands and chains
dail_h
   I use Simmons ,and the Tech s from Cook's,tried the Munks,had breakage issues. I think the blades are ok,but with small wheels they fatigue early.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
LeeB
Menemonee is cheaper than Cooks on the monks. Don't know about the rest of them. LeeB
