Francis Scott Key Bridge Collapses
Started by SawyerTed, March 26, 2024, 07:09:33 AM
rusticretreater
You notice in some of the shots, the crane ship is off to the side working on getting a sea lane open.  That's probably where the workers were cutting the girders.
The real difficulty is getting the leaners off of the ship so that it can be pushed away from the area.
The rest of the operation is stuff that has been done many times before.  Getting enough flotation under the pieces and tow them away, cleaning up the sea floor and assessment of the remaining structures.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
CCCLLC
I'm  sure there is great anticipation for the shears.
LogPup
It looks like there are almost 30 ships anchored between the mouth of the Chesapeake and Annapolis.  Bulk carriers and Auto carriers.
Just happened across this video of the Port of Baltimore. Video made by a trucker picking up a CAT excavator that came into the Port from China, and he is loading it up to transport to Canada. The first 25 minutes shows the volume of equipment at this Port either moving in or someday, moving out.
Found it interesting enough to think other FF members might also find it interesting, both from the truckers side as well as the Port of Baltimore side.
A lot of our grub comes up those rivers, a lot from south of the US to. You would think a lot of the non US stuff could come into the Bay of Fundy with the deepest sea port on the globe. But it's an historical fact since confederation, the Feds will never give those jobs to a Maritimer.  smiley_thumbsdown ffcheesy Open ocean, no bridges, rail service. Why make it tougher? Subsidies and politics will always overcome practical things.  ffcheesy
gspren
I would think that the Bay of Fundy's extreme tide levels and currents would make for some challenges to cargo loading/unloading.
Never hear tell of it.  Even Churchill during WWII couldn't believe the government didn't use it all the more. Was easy to defend. There a number of small ports there, 40 or so. But could be expanded for a lot more cargo. A port or two may be closed in winter because of thick ice. But that is not the case for them all.
NewYankeeSawmill
Norwood LUMBERPRO HD36V2
Resonator
QuoteJust happened across this video of the Port of Baltimore. Video made by a trucker picking up a CAT excavator that came into the Port from China, and he is loading it up to transport to Canada. The first 25 minutes shows the volume of equipment at this Port either moving in or someday, moving out.
I hauled flatbed loads in and out of the Baltimore a few times. I had Oshkosh trucks going in one time, and compact tractors going out another. As seen in the video there are huge parking lots with all types of cars, trucks and machinery. Also there are huge warehouses where freight is unloaded out of containers and reloaded on trucks to be delivered. All of this dependent on the ship traffic in and out of the port.
Those ocean transport ships seen in the video have multiple levels inside, with ramps going to each area like a floating parking garage. The ships crew has to plan out the loads on each level like a giant chess game. Deciding where each machine and car gets put, sometimes with multiple stops around the world where different machines will get loaded and unloaded.
Streaming video showing live happenings at the bridge cleanup. Some traffic talk, which is Barge's world these days.  Offloading two containers at a time. Can just pick out the men on the Dali ship hooking up the containers.
BargeMonkey
Friend of mine got some good pictures the other day going thru, the boat I'm on brought down the container barge they are going to unload the ship with last week.
Messenger_creation_f6b223db-59d1-4a36-bdb8-201fd6d95960.jpegMessenger_creation_2258d4c4-8479-4a34-bee7-8f03416e5956.jpegMessenger_creation_f1e9656b-ed57-478e-927b-fe7ad9eeadef.jpegMessenger_creation_25b5d047-2312-43dc-b700-b2f6f6bfbbf2.jpeg
Awesome size of that steel bridge when seen up close, and the man on the bow risks further collapse not knowing what is holding up the bridge structure above him.
Live stream video that I watch shows progress removing containers, bridge parts, huge clam shells to lift pavement from the bottom depths, and the many, many tugboats operating to keep the hundreds of barges in position at the right time. What a job.
Live stream
https://www.youtube.com/watch?v=2sv7SA2Ybgg
A short video of some closer-up images of the damage, and the rescue operation.
Imagine that every tug has a "bargemonkey" working hard to keep the engines running. Hard to fathom how this entire operation can be coordinated.
gspren
   News tonight shows they have a smaller temporary chanel opened and are letting some ships/barges out, chanel will only be open for 4 days and then close while they remove more debris.
rusticretreater
Maryland Gov. Wes Moore said Sunday the container ship that caused the Francis Scott Key Bridge collapse in late March will be removed from the Patapsco River channel "within days" as salvage crews plan to refloat the ship on Monday.
There was a video the other day of cutting explosives being used on the trestle pieces laying on top of the ship.  Snipped it right up.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Talk is about floating the Dali early in the morning when the tide is highest.
gspren
They got it moving this morning about 7:00 which was high tide.
rusticretreater
The ship has been towed to a port for some repairs before heading to a shipyard for a real fix.  A bit of cleanup of the rest of the debris and Baltimore is open for business again.
Next up, a spectacular billion dollar bridge fiasco!
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Peter Drouin
Quote from: rusticretreater on Yesterday at 12:04:19 PMNext up, a spectacular billion dollar bridge fiasco!
ffcheesy ffcheesy ffcheesy Will see how that goes.  ffcheesy ffcheesy ffcheesy ffcheesy ffcheesy
A&P saw Mill LLC.
License NH softwood grader.
