Swing mill in Southern Maryland
Started by Dan_Shade, April 20, 2024, 09:30:15 AM
Dan_Shade
In Southern Maryland:
I have a client who would like logs sawn, but I can't get my mill to his logs due to the ~15% driveway grade (the back of the mill hits way before the tires go up the incline).  No option to pull in, but that would drag too.
Does anyone have a swing mill or other small mill that could be backed up a steep grade?  If so, please PM me.
lots of dull bands and chains
Can't drag the logs down?
Have a pic to post showing the problem, as it sounds insurmountable.
Hilltop366
Just need a wheel(s) at the back of the mill. :wacky:
dgdrls
Would it be possible to cross the grade back and forth with a team of people
pushing/pulling the mill up the grade?
D
longtime lurker
Couple stiff planks and split the angle maybe?
Dan_Shade
Thanks for the suggestions.  the logs are in a residential area, paved driveway, not much room.  driveway is too steep to get the mill backed up due to ground clearance issues.  A Peterson could get in there (getting the saw frame thing up the driveway would be a job).
jaciausa
At the site, possibly back it partially on to a tilt dovetail car trailer with another vehicle pulling it up grade!
