Circular saw gauge selection
Started by torqueporting, January 19, 2013, 04:36:41 PM
torqueporting
Has anyone run a 6/7 gauge saw in 50"? I am curious if the blade is too thick and overkill for smaller saws in average production speeds.
Torquer,If I recall mine is 7-8 but I really had little choice it came with the mill and a new saw is more than I can justify.As a rule you will have fewer problems with a heavier saw,slight loss of lumber.If you have it or can get it reasonable use it,just use bits and shanks little wider.Give us more information. Frank C.
torqueporting
My past mill experience is a 7/8 gauge 50" F saw with a 9 gauge 48" 2 1/2 back up. When the 7/8 gauge was out of commission we ran the 9. Sawing with the 9 was slower in that we could not push on that blade as hard. That mill is long gone and never coming back. I purchased a portable belsaw which came with a beat up R. Hoe 9 gauge 2 1/2 in 48".  I had the 9 gauge hammered with plans to run the saw for a year and then upgrade to different pattern and gauge.  This purchase will put me in the drivers seat to buy what ever saw I wish. When making the purchase I want to by something that will satisfy my needs but not too much overkill. I have to say I do like the idea of a 6/7 gauge saw.
ALWOL
   Usually the thicker gauge saw is needed on a high horsepower, faster feed speed production mill sawing in hardwoods, but I also would choose the heavier gauge for myself if I had the choice. You should still be able to run 9/32 bits if the saw is fairly well tuned. The heavier saw will be a little easier to control, and can take more abuse before needing hammering.
   Alan
There's a big difference between staying busy and making money.
