General Forestry => Drying and Processing => Topic started by: bushhog920 on March 02, 2021, 01:50:16 AM
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201104_085838185_HDR.jpg?easyrotate_cache=1614667600)
I know you guys love pics so here they are. Just ran my first load everything works great.
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201105_144308592_HDR.jpg?easyrotate_cache=1614667348)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201123_191723000.jpg?easyrotate_cache=1614667339)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201123_195321210.jpg?easyrotate_cache=1614667334)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201217_142316948_HDR.jpg?easyrotate_cache=1614667324)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201123_204427976.jpg?easyrotate_cache=1614667317)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201214_174217911.jpg?easyrotate_cache=1614667310)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201214_174400390.jpg?easyrotate_cache=1614667302)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210126_161147525.jpg?easyrotate_cache=1614667294)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210204_121228002.jpg?easyrotate_cache=1614667290)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210129_193055989.jpg?easyrotate_cache=1614667290)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210218_110226880.jpg?easyrotate_cache=1614667283)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210225_133149310.jpg?easyrotate_cache=1614667277)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20210225_103537739.jpg?easyrotate_cache=1614667277)
Looks god but I would have had the fan truss centered in the container for better airflow. ;D
Thanks for the input my idea was to offset 1' to the wet side so the baffle would be more centered on the lumber stack. Thought it is interesting the nyle fans don't blow a forward cone of air it's more like a ring at a 45°. Figured because of that it would be ok to be closer to a wall.
how did your repair on your roof turn out?
The hardest part of the roof and side repair was figuring out how to do it.
* Cut out all damaged foam and metal
* Used galvanized 2x4 like studs in a wall but laid them flat. On the ends I cut off 3 sides 2" back so I had a tab that I riveted to the container from the outside.
* Riveted down 4' wide sheet of 26ga galvanized to the outside with lots of silicone around the edges.
* 1" pink foam between the studs.
* 2" pink foam on the inside with 3" screws and fender washers to hold in place.
* Left 1/2" gap on the 2" foam and filled in with spray foam.
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201203_180657323.jpg?easyrotate_cache=1614786411)
(https://forestryforum.com/gallery/albums/userpics/20928/IMG_20201203_191620780.jpg?easyrotate_cache=1614786405)
Looks like you got it handled. Did your container have a stainless liner?
Yes. I passed on the ones with fiberglass interior didn't think they would handle the heat.
Nice work.
