Siatic nerve pain
Started by tree-farmer, April 26, 2018, 06:57:28 PM
Stephen1
I am lucky, Cathy is a Yoga instructor and  therapist and I do yoga once a week. Her specialty Yoga is geared to 50+ years of age. When I have problem with my back Cathy gets me stretching and exercising. It works.
doc henderson
traction is better than inversion for the neck since not much weight in an empty head!   :D :D :D, inversion really pulls on the lower back with the weight of the torso + the empty head.  both could work but it is what is easiest given the location of the problem.  would be best to find a good local doc.  If it is too hard to set up, folks will not do it.
firefighter ontheside
Thanks all.  I will definitely get to stretching and maybe yoga after I get an appointment with the doctor.  I will go see the one I saw a few months ago and go from there.  One of my coworkers works for a spine surgeon office , but also have a doc who specializes in pain management and injections.  I may go there for the injections when the time comes.
No doubt I have an empty head.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
doctorb
Agree with much of the above advice.  I would add that I would not see a spine surgeon initially.  Rehab docs, Pain specialists, PM&R (Physical Medicine and Rehabilitation) specialists evaluate the cause of your pain and try to stem it non-surgically.  Unfortunately, us surgeons often only see the scalpel pathway.  When the first line of defense fails after considerable amount of effort and time, they will refer you to the surgeon.
doc henderson
I just went to my second physical therapy apt. for my neck and arm symptoms.  If the only tool you have is a hammer, everything begins to look like a nail. :)  My colleague has had two neck surgeries and they turned out well, a discectomy I think.  He is happy.  still last resort, but the question is how long to suffer until crossing that line.
Old saw fixer
Quote from: doc henderson on July 20, 2023, 09:58:23 AMstill last resort, but the question is how long to suffer until crossing that line.
I went a long time before my total hip replacement, dreading surgery.  Now I wouldn't hesitate!
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M
Echo CS-2511T, CS-3510
Logrite Cant Hook (with log stand), and Hookaroon
Thanks guys.  I assume that my original doc is a surgeon, but perhaps not a spine surgeon.  He is supposed to review my MRI and get back to me on treatment options.  I could not get an appointment with him til middle of Aug.  Assuming he gets back to me tomorrow or early next week, I will decide whether to make an appointment with him or find another doc.  There is a practice that I have been to for my elbows that I assume has at least one suitable back doc and or pain specialist.
Doc Henderson, what's going on with your neck and arm?
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
doc henderson
some impingement C 5,6, 6,7.  weak triceps x 2/3, pain/tenderness in rhomboid, tingle in the thumb and finger 1 & 2 or digit 123.   :snowball:
Ed_K
 I tried everything listed above until I couldn't walk and pain so bad all I could do is lay fedal style and cry. Crawled onto gurney and into surgery. When I woke up I slide to the side of the bed got up and could walk again. That was in 1995, now it's getting bad again, now I'm waiting till my cancer numbers come down enough to have the surgeon do the ballon thing where they put a small balloon type thing into the L4-L5  where the disk used to be and blow it up, squirt some cement in and pull the baloon back out thru a small hole in my back. The Doc's can explain it better.
Ed K
I finally got sciatic nerve relief when I loosened my belt and started wearing suspenders.
doc henderson
Ed that is prob. a kyphoplasty, and it jacks up a crushed vertebra with a balloon and then glue goes in to stabilize with instant results if it goes well.  it is for a compression fracture and goes in the center if the bone.
I am working on getting the fluoroscopic guided epidural steroid injection scheduled.  Im not impressed with the office im working with, but I think if I try to go somewhere else right now, it will delay the process.  I think I will likely have this doc do this one and then schedule with a new doc for further care.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Ed_K
 So Doc, what would be the best way to fix the disk between L4 and L5? not that this will be coming up soon.
Ed K
doc henderson
It would depend on the issue on MRI, but surgery should be the last option other than the first.  steroid epidurals help with PT.  the people I know that have had the micro discectomy however are happy they did.  always a chance of a complication or lack of relief that you must weigh the potential benefits against.  find a good pain doc or neurologist to assess first.  If the only option becomes surgery, then they can refer you.  this is for the chronic conditions not for acute injury needing to be stabilized.
My epidural was scheduled for Aug 14, but just got a call from the doc office that they had a cancellation and now I am going this Friday, Aug 11.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
I had the epidural yesterday.  I thought it would be more painful than it was.  Ironically my pain has not been too bad the last week, but I know it would come back.  Hopefully now the pain won't come back and what I still have for pain will be reduced.  The doc said that the damage to my discs is not as bad as what the MRI report sounded like.  He brought up some pics and showed me some things and showed me where the shot was going to go in relation to the bulging disc at L5-S1.  Feeling pretty good today and back at work.  Luckily its a weekend and I can take it pretty easy.  I got an injection in my elbow on Thursday and that hurt worse.  Talked to the doc about surgery this fall for that.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
