Is a matcher valuable for a small operation?
Started by TKehl, January 30, 2020, 08:35:20 AM
TKehl
Is a matcher a valuable piece of equipment for a small operation?
I have a small operation and plan to stay a one man/family operation.  Trying to avoid buying logs and focusing on adding value into what comes off our couple hundred acres of timber + custom cutting and processing.  This is still being setup, but will probably not be full time even when setup.  The idea is to go from tree to trim/flooring/siding/etc..
I have a decent amount of equipment already.  2 woodmasters, 30" planer, 24" jointer, an old flat belt moulder, and many smaller pieces.
Would a matcher add value for a small volume operation like mine?  The one in question is 14-18k Lbs and would need 75 HP or so to run well.  Already stretching my limits to physically move and power.  My hunch is the answer is no, but was curious to see if there is something I'm missing before I turned it down.  Seems more like the semi loads a day level where my focus is more of a pickup load operation.   ;)
Better to ask here than OWWM as that group is a bunch of enablers, though I love them for it at the same time.  LOL  "Yes you should buy it, what is it again?"  :D
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
Southside
White Oak Meadows
TKehl
No, 4 sided planer.
I should have clarified...
muggs
TKehl
Tractor PTO or stationary diesel engine.
We have one sitting around where near everything is worn out but the engine and PTO.  93 HP at the PTO according to Tractor Data.  Probably a little light compared to the torque of electric, but at slower speeds, it would work.
Have a 6 cylinder Continental with a hand clutch looking for a job as well...   ::)  :D
Southside
White Oak Meadows
