Author Topic: used motor oil  (Read 3171 times)
Offline SPIKER
Re: used motor oil
« Reply #20 on: November 26, 2013, 11:15:11 PM »
If you watch Menards and TSC you can buy it for under 5 bucks a gallon, last two years gotten it for $4.99 at Menards a couple times.   few years back spring clearance at the local kmart bought 3 gallons $2.50 each  8) I picked up two gallons at menards month or so back so set for a while...    maybe lol
I'm looking for help all the shrinks have given up on me :o
Offline coxy
Re: used motor oil
« Reply #21 on: November 27, 2013, 06:33:05 AM »
cant get it that cheap from tsc around here  ;D
Offline thecfarm
Re: used motor oil
« Reply #22 on: November 27, 2013, 08:54:38 AM »
I saw that before on here too. I think tsc here in Maine is $8 the cheapest. I was buying Poulin brand when the price of oil first jumped at walmart for some really low price. I could not go by a walmart in our travels without stopping and checking. I would buy a case,6, if they had it. Sometimes less than that,if that's all they had. That stuff was some thick too. I only used it in the summer. But I noticed tsc have changed the look of the jugs and maybe who they buy it from too. Seem to be stringy than the stuff they had before. I pour it into the saw now and I have to wait for it to finish the pouring part now.
I use to buy it from a discount store on the way to work. I would buy a case every so often. That was the cheapest place that I knew of. Than the price jumped and that was it for that place.
Offline routestep
Re: used motor oil
« Reply #23 on: November 27, 2013, 09:30:57 AM »
Car motor oil has a lot of additives in it. Way too many to be spreading it around my woods.
Offline shootingarts
  • Location: South of the Border, the Mississippi border near I-55
  • Came here to edit and nuth'n to say
Re: used motor oil
« Reply #24 on: November 27, 2013, 11:31:53 AM »
Thirty weight was the gold standard when I started out. Thirty weight nondetergent for the bar set me back close to seventy-five cents a quart, sometimes it was billed as lubricating oil for about a dime more. The thirty weight ND went in the two-cycle mix sometimes but I usually ran thirty weight detergent in there, cost close to a dollar. Funniest thing I ever saw was the first can of oil labeled "two-cycle oil" for damned near two dollars a quart! The tiny little bottles for fifty cents each were hilarious too. What kind of idget would ever buy something like that? Danged outboards are what got me started using the two-cycle oil, been downhill ever since.
Y'all caught my attention with the used hydraulic oil for bar oil. I got the oil, filters, and such sitting on the shelf to change out six or eight gallons of hydraulic fluid in my John Deere tractor right now, or at least as soon as this cold snap ends. May not be cold in some parts of the world but low twenties and windy is cold down here in the swamp. If that hydraulic oil makes decent bar oil after being drained and strained a few times I have enough bar oil to last me for life. Takes care of the disposal issue too. Would be worth the aggravation of trying to clean the solids and such out of it and pour off the top stuff a few times leaving the dregs behind.
Hu
Offline beenthere
Re: used motor oil
« Reply #25 on: November 27, 2013, 01:15:48 PM »
shootingarts
"DanG" is the official word to use on the Forum.. just FYI  ;)
And hopefully you don't have much for dregs in the used hydraulic oil.
Where is "down here in the swamp" ??  Could fill in your bio, and that would help out where "here" is.  thanks   :)
Re: used motor oil
« Reply #26 on: November 27, 2013, 03:33:50 PM »
shootingarts
I'll bear that in mind about Dan G even though I have never met him! ;D
Been in the swamp most of my life, south Louisiana and under ten feet above sea level, often a foot or two give or take. I have moved to the hills recently, north of the I-10/I-12 line. I'm on an old hundred acre dairy farm. Routine maintenance and turning wood from log to bowl or hollow vessel on a lathe has me using a saw a few times a week most weeks.
The tractor belonged to a cousin who purchased it new and paid the local John Deere dealer where he was at for regular maintenance. Since I have found few other things he paid for were actually done I suspect the hydraulic fluid and filters haven't been changed since it was new. The tractor isn't being used much now so by dregs I mean I suspect I'll find some water contamination, some metal filings, and hopefully that is all, maybe a little rubber. Leaving the bottom of the drain bucket behind I hope to not stop up the oiling system or cut up the oil pump on my saw. I don't mind losing a half gallon or so of fluid when I was going to haul all of it to the recyclers. I'll still do that with what I don't use.
I'll try to put up a little thumbnail bio later. Not too good at thumbnails as my posts indicate!
Hu
Offline bandmiller2
Re: used motor oil
« Reply #27 on: November 27, 2013, 08:55:09 PM »
You just know bar and chain oil is made with the cheapest grade of oil they can find with a dye and tackifier added. Probibly most are made with recycled oil. Hydraulic and ATF are excellent lube and usally not contaminated with unsavory products of combustion.If left to settle most contaminants will drop out.I used to use turbine oil especially in the winter. Frank C.
Offline Al_Smith
Re: used motor oil
« Reply #28 on: November 27, 2013, 09:13:46 PM »
Al, are you saying you actually BUY oil?  :D
Well in a manner of speaking but it's been several years .
You see I'm somewhat ingenious and a miser .My bud the tree trimmer has a brother in law who works in a repackaging plant that bottles oil .Any leakers or stained jugs the employees get it for nothing .I must have 20 gallons of Dextron II plus about 5 gallons left of bar oil .
The trimmer is a snob .If it doesn't say Stihl on it he won't use it .
Offline Al_Smith
Re: used motor oil
« Reply #29 on: November 27, 2013, 09:19:22 PM »
Now this oil business .Exactly what is oil .Geoligists say it comes from organic plant life that was trapped under the earth for several million years and turned into oil .If not oil coal ,peat etc .
Now sure something the size of the Exon Valdez that runs agound can cause serious ecological damage .The BP well in the golf made a mell of a hess .
A tiny bit of bar oil ,now that's kind of nit picking in my way of thinking .I'd bet the two major highways crossing Allen county Ohio ,I-75 and US 30 have more oil leak out of cars in one single day than all the chainsaws blow on the ground in one year .
Offline Al_Smith
Re: used motor oil
« Reply #30 on: November 27, 2013, 09:26:48 PM »
So here they come with eco friendly bar lube ,jellied water .Industrial KY jelly is all it is ,water with a jelling agent .
Does it work ?I'd say if it does then  these serious eco minded people would be wise to use it .What possibley could water hurt ?Save the salad oil to go on salads and the ethanol to make good corn whiskey and fatten cattle or use the salad oil to fry up the hamburgers from the corn fed steer .--mumble grumble --
Electric motor in place of gas motor on saw mill
Started by Freddie on Sawmills and Milling
Last post November 21, 2019, 09:14:07 PM
by Kindlinmaker
Motor 353 gm or 453 gm
Started by parlee8920032001 on Wanted
Last post January 13, 2019, 04:06:13 PM
by Trapper John
Bar Oil Vs. Motor Oil?
Started by daveferner on Chainsaws
Last post December 27, 2013, 07:43:11 AM
by bandmiller2
How to tell if an old motor is 6V or 12V?
Started by StorminN on General Board
Last post May 19, 2009, 10:00:40 PM
by John Woodworth
