Weiler Forestry Equipment
Started by Riwaka, August 25, 2022, 10:36:52 PM
Riwaka
Weiler F848 Forwarder 8x8 - weighs 51K lbs and payload of 44K lbs 13 mph - higher speed. Could be a Palfinger crane.
https://www.weilerforestry.com/equipment/forwarder/f848/
Southside
I wonder what that bad boy costs.  Can I get it with the optional sharks with laser beams on their heads?  :D
White Oak Meadows
Firewoodjoe
I wondered when they would come out with a forwarder. They basically took cats forestry equipment I'm guessing. It's resigned but they have a nice looking track harvester. Like the cat 501 or fabteks. But that forwarder I'm not sure about. Visibility looks horrible from the outside.
Firewoodjoe
I see the local cat dealer just put a weiler grapple Skidder out front on display! I bet some harvesters will be around here before long.
Riwaka
ehp
they are to come out with a smaller grapple skidder fairly soon , have no idea on the price
B.C.C. Lapp
Quote from: Firewoodjoe on August 26, 2022, 11:46:32 AM
Joe that's the first thing I thought as well.  Looks as bad for forward visibility as an old 540 A cable skidder with the high front end.      Must just look that way though. Must be different from inside.   They wouldn't engineer something with that big a flaw now would they?
Listen, or your tongue will make you deaf.
quilbilly
Quote from: ehp on October 08, 2022, 06:33:22 AM
How much are the current skidders? I read somewhere that they were on the cheaper end but haven't seen anything to prove it. Tigercat, then Deere is Weiler close to Deere or definitely lower?
a man is strongest on his knees
Firewoodjoe
Quote from: Riwaka on October 08, 2022, 05:35:00 AM
Weiler H157 with a fixed processor.
Update Your Browser | Facebook
I like what I see in them. Not sure about the cat engine though.
Riwaka
timbco68
Believe it or not, around here Deere is more expensive than Tigercat. I priced skidders last year and was surprised that a new Tigercat 620 is cheaper than a 648L2
GuideGun
Jon cuts for the forestry company I used to work for. He had some problems with that 157 and Weiler ended up taking it back. He ended up with a Weiler 457 and Waratah 623 instead.
Riwaka
Firewoodjoe
