Winch Slip
Started by thebull204, April 09, 2024, 09:48:29 PM
thebull204
Evening All  just a question --- I have a Timberjack 208 that worked well thru the winter ( central Canada ) so we have our share of cold days here. Have been running light hydraulic oil in it -- went to use it today and its pull a load in fine but wont hold it up.. Start to drive away and its reels out slowly - any chance the oil is to light ?                     ( + 15 celsius)  here today
Kodiakmac
It might help if you can tell us the make and model of the winch you have.  There is likely someone here who has had the same model with a similar problem.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
Did you take covers off and make sure it's dry?
OntarioAl
The holding band is held on by spring pressure hydraulic pressures releases it and activates the clutches that power the winch drum
Oil viscosity has nothing to do with your problem
I suspect the spring is broken
Cheers
Al
Al Raman
