Finally back to milling
Started by Kingcha, June 01, 2019, 11:34:35 AM
Kingcha
I did very little milling last year do to, to many projects around the new house.     Well the first major project on my list this year is a Lawn Shed.
Maybe I should say heavy duty lawn shed.
Except for the treated sill I am using all my own lumber.  Built like a pole barn except the post are attached to the concrete instead of burying them.   Will do a steel roof then wood walls.
I have to thank the forum as I had to do a little refresher of the mind and the search feature worked great.  Thank you all for posting your knowledge.
Matt
a Wood-mizer LT15 10hp Electric, 45hp Kioti tractor, electric smoker, wood-fired brick oven & yes a custom built Solar Kiln
Ljohnsaw
Very nice!  About 8x10 or so?  Its so nice to have a slab floor instead of wood or dirt.  Board and baton for the siding or a T&G/shiplap flat board wall?
John Sawicky
Kingcha
Thanks John  10 x 12   I'll be doing board and baton.   I'm very happy I spent the money for a slab.
matt
