Author Topic: Have to do it  (Read 1081 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Have to do it
« on: November 15, 2021, 06:23:53 AM »
The bearing went bad, It had to come apart.
Some wheels were not square after hitting bark or knots. So I use a pointed bar to bring the steel plate back.
This one had to come down some. Not much adjustment on the offset bolts.
I'll have it all together in an hr.
Looks like more rain today.  ::)
Happy I have over 300' of roof over me.
A&P saw Mill LLC.
License NH softwood grader.
Offline Bruno of NH
Re: Have to do it
« Reply #1 on: November 15, 2021, 06:34:21 AM »
Hi and dry is nice
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Have to do it
« Reply #2 on: November 15, 2021, 08:34:01 AM »
I bet pulling that all apart makes it easier to understand how it all works. I always have troubles when it comes to adjusting.
a roof is nice especially this time of year.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Have to do it
« Reply #3 on: November 15, 2021, 06:37:01 PM »
Done that with my lt40 super. Good to not be in a hurry with that job.
The LT70 super has easier adjusting for that, no cam bolts anymore but hitting the guide arm or setting the blade or debarker on a cant is still$$$.
    • A&P Saw mill LLC
Re: Have to do it
« Reply #4 on: November 15, 2021, 08:49:09 PM »
Just when I thought it was going to be easy.
Happy, I had a replacement on a shelf.
A&P saw Mill LLC.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: Have to do it
« Reply #5 on: November 20, 2021, 08:18:12 AM »
     Peter, you're right about that plate being out of whack.  Those adjustments are hard enough to make when everything is square.  It's DanG near impossible when one of those cams is out of alignment.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
Re: Have to do it
« Reply #6 on: November 20, 2021, 08:26:08 AM »
That adjustment is a pain.  I remember I spent hours on it one time, and later found that a cam bolt was badly bent by me putting too much wrench in it, which only made it worse.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: Have to do it
« Reply #7 on: November 21, 2021, 11:53:50 PM »
Definitely my least favorite adjustment
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
