What do these blade marks mean?
Started by squarpeg, June 20, 2021, 05:27:26 PM
squarpeg
I was sawing away and all of a sudden the cut looked like pic. What is cause?
NOTE FROM ADMIN. OFFSITE PHOTOS NOT ALLOWED. PLEASE READ RULES
Chuck White
It means that you have at least one tooth that is set to much!
Crossroads
Good chance you hit a rock in the bark and bent a tooth if it came on suddenly.
terrifictimbersllc
Often you can go back to the place in your sawing where the cut changed from smooth to rough, and see the reason for it (nail for example). A pebble in the bark can do it too but that is harder to prove what it was.
You need to post that picture by loading it into your FF photo gallery and putting a link to it from there. Otherwise if that link goes down or you remove that picture then this thread becomes meaningless.
firefighter ontheside
Definitely at least one tooth out of correct set.  Every time that tooth or teeth come around they leave that mark.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
btulloh
Well good job getting the picture in your gallery. Can be a bit of a learning curve for some, but it pays off because the pictures will always be in the post. Not true on many forums.
Chuck White pointed out the issue.  You may or may not find what you hit, but if look over the blade you'll find a tooth or two with the heavy set. There may be some other visible dame to the the tooth, but for sure it's going to be set way more than the others. Just part of the sawing experience. None of us are ever through learning.
HM126
squarpeg
moodnacreek
Bend out a few more to make drying sticks.
YellowHammer
Yep, you hit something.  No big deal, it happens.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
backwoodsdave
Some people pay extra for saw marks in their lumber, just had a buddy of mine cut some for a lady who wanted that very look, some extra set in a couple of teeth and your good to go.
moodnacreek
The man I just got a sawmill from says historically correct up and down sawn beams can be reproduced with a small band by bending a few teeth out and raising one end of the cant.
