Is this a spiral head with individual inserts? Or is it straight blades? Got a photo? That hex key sounds awful tiny for what it is doing. 2.5mm is less than an 1/8".
Red Loctite? That’s the wrong use for it. It’s doing what it’s supposed to do. Heat to soften the Red Loctite, tap in an easy out, remove them with a light air wrench, and replace them and use Blue Loctite.
Changing inserts is a task my partner has always done, I'll try to remember to ask him tomorrow. Bolts here;Lucas Mill Carbide Insert Screw (Mx X Box Of 10 (baileysonline.com)Inserts;Lucas Mill Parts - Lucas Mill Portable Sawmills - Portable Sawmills - Sawmills & Planers (baileysonline.com)Here's the instructional videos for the planer head;Hmm, that bolt link is doing the disco, you can get to it from the insert link, its on pg3... you'll end up calling it in anyway but this lets anyone curious check out that attachment.
Good news. One of my wood customers took the planer head to work where a guy with a screw extractor, left handed drill bit type of thing, took all the screws out easily.There is a bottle of Loctite 222 that came with the planer. I think it is in a red bottle (but I'm too lazy to go out to the shop to look). Maybe that is where the "red" came from.The pack of replacement cutters has arrived, but the screws aren't due until Friday. I'm not going to try to use the old cutters. They have two good edges, but part of each cutter insert is broken off. Everyone -- thank you for the ideas and suggestions.
Started by bandmiller2 on Chainsaws
Started by D._Frederick on General Woodworking
Started by Brad_bb on General Woodworking
Started by ToddC on Drying and Processing
