Useful sawmill mods
Satamax and 8 Guests are viewing this topic.
Peter Drouin
They do, I was going to cover mine with an old leather apron. I'm inside too.
Lawg Dawg
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
I went through several seats until a bought one from Tractor Supply, made to fit a Kubota tractor.  It's a good one.
Chuck White
I have thought about modifying my operator seat with a wheel that will be on the ground, outboard of the sawmill tire, with a small platform (maybe a foot square) just big enough to stand on while going back and forth!
This is not a "mod" as such but just an idea to eliminate a nuisance at times.  Sometime when I return the saw head I'm going a bit too fast and hit the bumper which in turn causes the control panel lid to close.
I have these little round magnets that hold notes, cut lists, etc. to the inside of the lid so today I thought about moving one of them to the top of the control box.  It worked perfectly and held the lid open/up during an unplanned sudden stop.
I'm too DanG old to slow down!  wheeliechair
Southside
It's got a diesel motor and it's really souped up
That Model A ride along seat makes it look like a pup
It's got four cylinders, uses them all
He's got Turbos on it, they just won't stall
With Accuset running and the straight exhaust
The logs turn to lumber and none get lost
A flashy taillight is all you can see
As another gum tree fell he said "Boys that ones for me"
He was in pattern mode and cranked the pot to 10
It was all she had, he hit top end
Sawdust was flying
He hit the bump stop at the end
The cover slammed down, he said "not again"
The cheat sheet fell, the pencil was wrecked
Lunch will be late, I suspect
All at once I heard him say
"Stick one here, this won't happen again today"
After that all you heard was the brushes clinkin'
And the boss man saying -
"That thing reminds me of a hot, rod, Lincoln"
move_it smiley_guitarist smiley_trap_drummer
And he is a poet, to boot :D.
boonesyard
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
gdaddy01
Bandmill Bandit
Too funny but kinda true to I think.
 smiley_heh_heh  Who da heck was he talkin 'bout??   smiley_headscratch
terrifictimbersllc
Hint...he needs a small vacation, and it don't look like rain....
Well at least we now know what his occupation is or was.  :D
Peter Drouin
Going to try this for a while and see how it goes.
When I get it the way I want I will fix the pading.
Chuck White
I like your mod, Peter!
The one thing I always disliked about the Operator Seat was the lack of "easy on and off", and it looks like yours will be basically just turn and step off!  I like it!
No cup holder. :D  Looks good.
petefrom bearswamp
I have been getting a rubbing sound when raising and lowering the head, only for a portion of the travel.
I lube with ATF religiously.
Checked the pad adjustment and all was OK.
Manual says be sure to check with the head at the top and bottom of the mast only as there may be a variation in the mast itself.
I suspect this is the case, but dont know why it has just started making the noise.
I am thinking of replacing the pads with a material called nylatron.
It is nylon impregnated with a lubricating substance.
It is used for some pretty heavy duty industrial applications and is available in 2x2 sheets of varying thickness.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Check your sawmill leveling side to side and end to end.  You may be able to tweak it a bit one way or the other which would change the mast balance and could make a difference.
Chuck White
You could also have a wood chip in a place where it rubs at a certain point in it's travel!
YellowHammer
I had the same thing happen when the mill mast wasn't vertical or had changed angles.  The pads would drag on odd, unloaded portions of the mast and cause the dragging.  Nothing wrong, after awhile, the pads would polish the new surface and would would stop making the noise.  Or I would re-level the mill.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Jim H
I've had the pads wear down until the bolts holding them on started to drag on the mast. That nylatron sounds good as long as it's not a lot softer than the pads supplied on the mill. I think they use derlin.
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
Jim_Rogers
Someone posted here on the forum, how they added some brushes to keep their belts clean.
I was walking through a store and saw a brush head that was wooden and bought it.
I cut it with my chop saw and have lots left to add more after these wear out.
drive wheel side:
Idle wheel side and left over brush:
Jim Rogers
