Looking for pictures
Started by Bruno of NH, May 26, 2022, 03:14:13 PM
Bruno of NH
I'm looking for pictures of what the 2 hydraulic pump system looks like on the lt40 super
I want to add a pump to my lt40 wide
I can't afford a new mill yet because I need to add some other equipment first.
ladylake
 If you mill is set up at home  get a electric motor and a hydraulic pump.  WAY more reliable and most likely cost less.  Steve
I have no idea whether your hydraulic box is large enough for a second hydraulic pump.
Both pumps are beneath the hydraulic controls and hoses see here.  You can see the actual pumps here to the left of the filter.  (They have the red plugs.)  The pumps are plumbed in parallel.
To access the pump motors the controls have to be unbolted and folded back.  Here the two 12 Volt motors are seen and can be removed for servicing.  I am presently replacing my motor brushes so these pictures were taken today.  I am 100% portable and have no problem with the electric over hydraulic.
Since you are home based, Steve's suggestion above may be the way to go.
Mooseherder
Quote from: ladylake on May 26, 2022, 03:30:02 PM
Is this the set up Bibbyman was running at his operation?
He had posted pictures of it.  Must be in his gallery.
Mooseherder
I just went in to look in Bibbyman's gallery.   Wow, what a wealth of knowledge there and in pictures!
This one was in his Mill modification and maintenance album.
trimguy
So just adding another pump in parallel would give you the fast hydraulics ?
@Bandmill Bandit did all of those mods on his iirc, basically turning it into a Super. I think he said he wished he would've just traded in on a super by the time he got done. You may have to go through the electrical, being that your wires and solenoids are sized for 1 pump. I would think an electric standalone pump might be money ahead, too.
That is a correct statement.  The loading limit is the same but at a slower speed.
This week one of my pumps started to intermittently fail and I could still load and turn but the speed was significantly reduced.  The working pump will overflow the failing/non-working pump so determining which is failing is easy.  I disconnected and also plugged the filler opening so I could continue and finish the job.
I pulled it this morning and 2 of the 4 brushes were much shorter so the motor was trying to operate on half of the windings.  That pump was pulling 130-140 amps where the working pump was drawing the normal 80-90 amps.  You will destroy a failing pump by continuing to use it.  I will "rebrush" both pump motors.
This and next week were already set aside for "dry docking" the sawmill for normal routine maintenance anyway so I am good with the time off.
I had intended to start a "Dry Dock" topic to detail the work.
Each hydraulic pump has it's own wiring and solenoid from the contact strip to the pump.  Two complete and separate circuits.
Dave Shepard
Some hydraulic hoses may be smaller on a standard vs Super hydraulic. Velocity fuses may also be different.
TimW
I sure would like to have a faster up/down speed.  Especially up speed while sawing cants that scrap the wires on the throat opening.  Seems like I can shine my shoes while waiting for the head to raise.  No other time does it bug me.
hugs,  Brandi
customsawyer
Quote from: Mooseherder on May 26, 2022, 07:59:34 PM
I bought this same pump shortly after Bibby added his. He had already done all of the work getting the pressure and flow figured out so that saved me a lot of steps. The next one I bought I just got it through WM as they offer them now. I like them as they remove so much headache. You can get rid of the strip and have hyd. anywhere on the mill. You don't have to fight as many electrical problems and there isn't near as much wear on your alternators or batteries. If you saw for a living and are stationary they will pay for themselves in less than a year. You will have increased production and less down time.
www.thecustomsawyer.com
DWyatt
I believe that Dave Shepard is correct about the hydraulic hoses. Most of the hoses on the mill will need to be up-sized to get the full benefit of the second pump.
DWyatt
Quote from: Bandmill Bandit on November 18, 2017, 02:26:28 PMI have, in the past 5 years turned my mil into what I call an LT40 "almost" Super! I have 1)  added the second Hydraulic pump 2)  changed out the 1/4 hydraulic hose to 3/8 as required 3)  changed the carriage drive to the 3/4HP 4)  changed the lift motor to the new small frame 3/4HP 5)  added simple set 6)  added my version of FAOs 7)  added a green laser site (my own version with Woodmizer mounting hardware) *   My engine is not stock as I have access to RD software! currently set for 36HP
I hope I did this quote correctly. It's a post I found with a quick search from Bandmill Bandit that describes what he did to get his "Almost Super" LT40
Quote from: Bindian on May 27, 2022, 12:35:18 AMI sure would like to have a faster up/down speed.
Brandi, the SuperHydraulic mill has ¾ hp up/down motors as well as the powerfeed motor.  I believe that the standard hydraulic mill has ½ hp motors.
EDIT: After reading DWyatt's quote, I see where most all of the questions are answered.   ;D
