sawmill upgrades
Started by DylanDiGuistini, February 23, 2020, 02:37:16 PM
DylanDiGuistini
Hi all, Below is my sawmill! have it in the shop after the shed roof collapsed. Gave me an excuse to add a few improvements. I was hoping to get some impute and general thoughts.
Note: I didnt build this, my dad bought it and I inherited it when he passed away last year.
Right now im working a guide rail as I wasn't happy with what was existing
Cheers
A-z farmer
Welcome to the forestry forum Dylan.There is many members on here that have built their band sawmill.I only see one small blade guide roller bearing I always thought there was two .Someone with the knowledge of building will be along .
Zeke
Looks like your log stops go straight up and down? I put inch marks on mine. I made them all ½ inch less. So 4 inch is really 3½ and 6 inch is really 5½ and so on. The marks really helps out when I am sawing flitches. Lets me give as much support as I can. If I set the head at 4 inches and the stops at 4 inches, I know I have ½ inch of clearance.
DylanDiGuistini
Quote from: A-z farmer on February 23, 2020, 07:17:54 PM
Zeke
Hi Zeke,
Thank you. I am very excited to be apart of the community.
There is another one, it is just hidden behind the plastic
DylanDiGuistini
Quote from: thecfarm on February 23, 2020, 09:05:18 PM
Looks like your log stops go straight up and down? I put inch marks on mine. I made them all ½ inch less. So 4 inch is really 3½ and 6 inch is really 5½ and so on. The marks really helps out when I am sawing flitches. Lets me give as much support as I can. If I set the head at 4 inches and the stops at 4 inches I know I have ½ inch of clearance.
Great idea! Thank you for the tip, what did you use to mark out the inches?
I used a paint marker, which needs to be redone every so often. When it starts to fad, I just redo it. Simple way to do it.
RAYAR
Quote from: thecfarm on February 25, 2020, 07:32:05 AM
I use a permanent marker, then spray paint it with an oil based paint. The marker will bleed through and be very visible. It will not bleed through with a water based paint. I also mark it on the side that gets the least wear and abrasion for longevity. The number you see above each line is the height above the log bunks.
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
Good idea!!
 The way I do last about a year. I don't saw much, so that helps. I will have to do that.
