Black walnut
Started by rooster 58, July 09, 2015, 09:07:59 PM
rooster 58
I sawed these beautiful  slabs  this morning into 6 & 8/4 thickness.  I felt they would make great coffee table slabs.
drobertson
they look killer Scott!  have to ask, blade got an off set tooth?
GAmillworker
Thank the Lord for second chances
rooster 58
Yeah Dave
       I actually bent the blade a little the day before when I ran the blade into the end of a log a little too hard. But as they say, it'll plane out ;)
drobertson
Yea, I kinda like the ribs once in awhile, they make nice touch off points,, killer looking live edge man,  I was hoping to get a good walnut tread going, just walnut, but we can use yours too, I don't care, I just simply love walnut when it comes around ya know.  Real glad you got things working your way, and bet you can testify it's a battle getting going,,
rooster 58
Dave you're  right again. You know the history of how I got my 70. It's a great mill, but at 10 yrs. Of age, even with only 198 hrs on it when I bought it,  I had many issues pop up with it.
     And other issues such as log procurement,  cash flow, theft, labor issues, etc. But things are looking up and I'm hoping to broker a sweet deal much like Custom Sawyer has.
     As for the walnut, it is one of my favorite  species. I'd love to run into some that I could make some gun stock  blanks  out of ;)
brianb88
That is some good looking wood
Measure twice, cut once
Planman1954
When sawing walnut, do you add anything to the water for blade lube?
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
POSTON WIDEHEAD
Quote from: Planman1954 on July 09, 2015, 10:35:24 PM
When I saw Walnut, I ALWAYS start off with a brand new blade.
I will saw through the log. When I bring the blade back, I wash the blade with lube ( water and soap ) to clean anything that may be on it. I then turn the lube off, let the blade run and sling any lube off and proceed with the next cut.
I do the same thing on each cut. I do not run the lube while cutting. Just my way of doing it.
Wow!  Here we go again.
Y'all treat Walnut like it is "very valuable" or something. ??  ???
Chuck White
I haven't sawn very many Walnut logs, but some, and when ever I'm sawing Walnut I always use a slow (1 drip/second or so) drip of water with soap mix.
rooster 58
Thanks for the  replies  guys! I just love to open up a log and see what's inside ;) it's almost like Forrest Gump's box of chocolates  ;D
Run Forrest Run.   8)
Delawhere Jack
Quote from: Magicman on July 10, 2015, 08:06:54 AM
It often takes me 3-4 opening cuts on the next job after milling walnut to get myself out of "walnut mode".
I don't like to leave anything in the slabs but bark. But then, I've also been known to lick my dinner plate clean after a good meal as well. ;)
rooster 58
Well...... it sure beats sweetgum :D ;D
YellowHammer
I don't saw it any different that than any other hardwood, except faster :D. Cotton picker spindle cleaner and water for lube.  Most logs are small, it's a pretty soft wood, there's lots of sapwood I have to whittle off, knots to dodge, and it's turn and burn.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
YellowHammer
Quote from: Delawhere Jack on July 10, 2015, 07:17:49 PM
Are you sawing so boards are sapwood heavy on one face and heartwood in the other?  White on one side of the board, dark on the other?
Any time I mill walnut worse than a 50/90 board, (50% heartwood on one side, 90% heartwood on the other) the board warps badly when it dries, pulling toward the sapwood.  Even though it looks flat off the mill, it will warp like a leaf spring when it's dry.  So I take heavy opening cuts, slabbing off white sapwood layers.
What do you guys do?
YellowHammerisms:
gfadvm
I too slab my walnut like you do with a lot of sapwood on one side of the top and bottom slabs. But I put 6 cement blocks on top of an 8' stack which has helped the cupping.
I have had the same problem with heavy sapwood on one side and heartwood on the other.  I just end up cutting the bow out by making shorter boards after the wood is dry.  Some people with buy a short walnut board with a lot of color.
Is it fact or fiction if you let a walnut log sit for a wile the dark will migrate and darken the sapwood.?? Frank C.
rooster 58
I have found that to be so in my limited  experience  with  walnut.  A few months ago I milled some walnut that had been cut for some time. There was little or no sap wood color to it.
     Another  sawmiller buddy of mine says the same thing
JB Griffin
I don't know if the color migrates from the heartwood but the sapwood will darken, or in some cases rot off. ;D
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
I have seen the sapwood gray stain, but never to the same rich color as the heartwood.
gfadvm
I haven't seen the color migrate into the sapwood. But I have heard that steaming the walnut will stain the sapwood to a closer match with the heartwood. Most of my walnut gets milled within a few days of being cut (I can't wait to see what it looks like!).
