Timberjack 608s
Started by Bradley66, July 22, 2022, 10:46:06 PM
Bradley66
I got a timberjack 608s was cutting with it and stoped to get a drink and when resumed it has no hydraulic functions at all tram, boom saw motor nothing it all went at once what could be causing this?
rusticretreater
This would all be guessing without some more information.  Of course, look for the obvious such as a blown line. Check the fluid levels.
Does the dash look ok?  Everything functioning and reading properly?
Examine how the hydro power is generated and that the pump is functional(belt, gear driven, electric).  Bad belt, blown fuse?  Is the pump really hot?
Is there any pressure at all in the lines?  Look for stuck relief valves, broken pressure springs.  Do you have a gauge to read line pressures?
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Grandpa
Firewoodjoe
My TIMBCO did the same thing. Ended up being no pilot pressure. And yes always check the door safety switch first.
timbco68
timbco's have a door switch that can give a problem
