Questions for 2x8 T&G roof decking nailing
Started by Lennyzx11, October 20, 2023, 06:40:32 AM
Lennyzx11
Hi all.
I'll get right to it.
I have a Bostitch 21° framing nailer that I'd like to use putting my roof decking on but want to make sure it's the right choice vs screws.
The pitch(es) are 7:12 & 8:12.
The boards are 2x8" by 16'.
Thank you for advice.
Lenny
1. 16 penny nails are called for 2" t&g I researched. That's a 3 1/2" length. What would be the corresponding recommended size (wire)? Galvanized, framing, finish, etc?
2. The ends are NOT face t&g. Do I need to land on a rafter with each connection and not out in "free air"?
(The rafters are 24-28" apart).
3. Is it 2 nails per supporting member for 2x8 face nailed? This will be covered with underlayment and shingles.
Southwest corner of Vermont
doc henderson
good morning.  will the deck be seen from the underside?  My framing nails are also referred to by the penny gauge.  I have used ring shank, but I do not recall them coming as large as that.  i think the ends should join over a rafter.  you could use a spline if it will be seen, and you need max. coverage.  you would hate to have an end stick up or down especially if seen.  My two cents, no charge!   :)
Lenny
What species? What is the underlayment intended to be?
Are you following manufacturer's recommendations with this fastening plan?
Lennyzx11
Quote from: doc henderson on October 20, 2023, 09:34:47 AM
I agree Doc. I didn't know if the T&G. Was consider sufficient support. I'll be safe and cut to the rafter support.
Lennyzx11
Quote from: beenthere on October 20, 2023, 11:11:23 AM
Lenny
It appears to be EWP or hemlock. I'll have to ask the local mill that made it.
There are no manufacturer's plans.
The Timberframehq plans stop at the frame and only the notation "2x t&g decking" is on the plans.
Hence I thought I'd ask you guys best practice guidelines.
The underlayment is intended to be old school 30lb felt but I'm open to suggestions otherwise if warranted.
Lenny
rjwoelk
I would go with self adhesive  ice and water shield membrane.  Why are the rafters 28 inches?
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
I understood underlayment as OSB or plywood.
With felt, I think you will telegraph the individual deck boards through to your shingles unless wood shingles. The decking is going to move, I believe, with mc changes and drying in place.
doc henderson
Don P
This is from the nailing schedule in chapter 6 of the IRC, check out item #25
My gun shoots 0.131's so by that table I'd put in 4 per bearing. Most people have never driven a 16 common, I think a sinker is .149.
This is from the AITC Timber Construction Manual. It explains controlled random layout patterns.
Lennyzx11
Lennyzx11
Quote from: beenthere on October 20, 2023, 03:33:24 PM
Hmmm... I never thought of that. I assumed the 2x8s as structurally sound but never thought about the flexible layers on top forming to the board lines.
Something to think about.
Thanks for the heads up!
Lennyzx11
Quote from: rjwoelk on October 20, 2023, 02:34:20 PM
The plans called for 30" on center. With the way it worked out due to a small extension to accommodate some length added to tie to the old shop, the distances ended up being 24" between to be uniform. So 28" on center.
I have been leaning to using the membrane. I used it on my wraparound porch that I built on the house and liked how it turned out.
Lennyzx11
Quote from: Don P on October 20, 2023, 06:49:39 PM
Thanks Don. Mine shoots .131 also. So that recommendation of 4 per support sounds like a plan.
scsmith42
Most framing nailers won't shoot 3.5" nails, so be sure to check your maximum length.
I had to buy my 3.5" ring / spiral shank nail gun nails from Maze.  Expensive but top quality.
Locally I can only buy 3"
Tom's 3638D Baker band mill
Ljohnsaw
My Porter Cable will shoot 3.5" nails.  I bought some to toenail the blocking in my floor joists.  It's a 21° gun so it uses the plastic connectors on the strips.  The nails shoot fine but the thicker wire with the plastic doesn't slide well in the magazine.  So, after each shot you have to bang it or physically push the strip forward.  Kind of a pain.  BUT, much better than hand nailing!
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
